Question about Philips GoGear Flash MP3 Player
My computer won't let me charge my unit...The first time was fine, now it won't even turn on... The phillips comes on but then goes off when i let go of the on /off button....The little sun doesn't show up and it is plugged into my computer and I see the charge going, but my computer says it can't install gogear....The unit is not that old.....also there is a foreign language under the picture of the charge action...
  • Philips Master
  • 17,130 Answers
What should be done is to RESET the go gear.
Look on the side and you can see a very small hole, insert a office pin and press and hold.
Now you gogear error must be gone and will mesh up with the PC.
Please try and install only recommended files as corrupt files will let your gogear hang up.
After connecting to PC do a scan and remove any malware or virus.
Credit if the advice helps.
Posted on Aug 26, 2010
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
Brookstone Boom Bucket BL646 battery won't charge
The battery in these units lasts about 3 years. If your unit is new, be sure the unit is ON (indicated by orange light in front) while being charged. Also, be sure to turn it OFF when not in use or the battery will be depleted (even if not used).
The good news is that the battery is easily replaceable. Removed the 4 phillips head screws from the bottom of the unit. With a little persuasion the bottom will come off, and expose the battery. Pull the battery out until the terminals are exposed and remove the wires attached to them. You can use needle nose pliers to assist if they don't come off easily.
Purchase a replacement battery online or at your nearest batteries plus store, install and continue to enjoy your boombucket.
The battery is 12V 3.3AH/20HR Lead acid type.
May 29, 2012 | Computers & Internet
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
Sony pocket ereader frozen on "are you sure you .....delete items. tried reset many times ...won't work. it is fully charged. plugged in to computer & no lights come on ... computer does not...
Hi shianto,
Because of e-ink screen technology the reader will display last page even if the unit is not charges it may display "full". Try this:
1. Connect the reader to the PC and check if a redlight comes up
2. If there is no light, hit the reset at the bottom for 3 seconds, the light should come on now.
3. Leave the unit charging for about 15-30 minutes
4. Unplug the unit and see if its operational now, if not you can try the reset again and the slide the power switch
eBookBoy
May 14, 2011 | Sony E-reader Portable E-book MP3 Player
Has never charged, even after extended time periods - both with car charger and usb. Any tricks I'm missing. I've tried "ejecting" it but it just goes back to showing computer connection....
Sounds like the internal battery won't hold a charge and needs to be replaced. If you're "handy" you could do this yourself, but it's not for the faint of heart, and replacement batteries are available on the Internet. Here's a video that shows the procedure for disassembling and reassembling it to install the replacement: http://www.youtube.com/watch?v=PwAbKYOgiZg
May 11, 2011 | Garmin nuvi 255W GPS Receiver
My Zen Mozaic is dead, won't charge on ANY computer. Was fine b4.
I had this problem myself and the solution is really simple. As you look at the Zen, turn the left hand side towards you. Near the bottom you will see a very tiny "reset" button. Press and hold (with a pin or fine pen tip) for a couple of seconds, then try turning the Zen on. It worked for me
Sep 12, 2009 | Beond Creative Technology Zen Mozaic MP3...
My Garmin c340 has won't turn on, screen is completly dark unit is charged
I has the same problem with a streetpilot 540.. It wouldn't turn on, even once charged. There was no reset button under the serial number. However, prise off the grey plastic square plate on the front panel which goes around the screen. ( there's even a little space for your fingernail under the Garmin logo). The reset button is under that plate. Press that with a screwdriver then turn on. My unit turned on once reset.
Aug 10, 2009 | Garmin StreetPilot c340 GPS Receiver
My GPS won't turn on or won't charge
Have you tried replacing the battery.
Wont charge? Sometimes if the battery is totally depleted even the charge light will not go on until the battery reaches a certain level of fill. Are you sure it isnt charging? A new battery will confirm its viability to be able to deliver service in future.
Jul 31, 2009 | Sony NV-U44 GPS Receiver
Nothing works
Does it say Philips and then go dark? If so, try pushing the reset button. Mine did this yesterday, because I did a complete erase. I had to push the reset a couple of times, then it started working again. I'm back in business, and listening to my songs as I type this.
Is your battery charged fully? Did you let it charge via your computer?
Jun 29, 2008 | Philips GoGear SA3125/37 MP3 Player
Philips GoGear Flash MP3 Player Logo
64 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
