Question about Biostar Computers & Internet
My pc shut down after five minutes aupply is ok motherboard and processor is also ok so tell me solution plz
    Sergeant:
    Champion:
  • 390 Answers
Try reseating the memory.and clean the processor and heatsink off with some isopropyl alcohol and reapply some thermal paste,and reassemble.
Posted on Sep 03, 2010
My problem with the Gigabyte GA-8I848P-G Motherboard is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is...
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
Jun 22, 2011 | Gigabyte GA-8I848P-G Motherboard
Ok i read some forums on the web about the amd am2 5800+ processors and it says nothin about them overheatin.. so down on the forum it said that when the cpu shut off from gettin to hot to feel the...
try this, open case then plug off processor cooling fan, then plug off processor, clean it, then plug on again the processor and cooling fan, if need take more fan on your pc then turn it on, if still like that it mean you must change your processor
Jan 23, 2011 | Abit Fatal1ty AN9 32X Motherboard
My pc shuts down when i start autocad 2010.I have 2GB ram,core 2 duo processor,motherboard-intel.what's the problem??
Plz Read System Requirement for Autocad 2010.
OR
Try removing Autocad.
OR
Formate your PC and install again Autocad.
Aug 21, 2010 | Computers & Internet
Amd motherboard prob
Which operating system are you using?
Did you install the CD that came with your motherboard?
Do you have a good virus checking program on your computer and is everything updated?
When was the last time you scanned for viruses?
May 12, 2010 | Intel Motherboard
I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
But, go to www.extremeoverclocking.com. This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
Sirwriter
Nov 05, 2009 | Intel DG31PR Motherboard
Cpu fan error, but spins
hi,, there may be an problem faulty in motherboard,, or processor,,,
Sep 28, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
PC starts up, afterlogi n locks up. Afr restart no signal to moni
Remove the RAM from socket. Clean the RAM contacts with pencil eraser & then refit RAM.
Hope this solves the problem..
Nov 29, 2008 | ASUS P5S800-VM Motherboard
Data recovery from a bad power unit
Your data on the HD is probably OK, If the PC powers up and then shuts off it usually is a heat problem. If it shuts down quickly it may be a sensor on the motherboard that detects heat and may be bad and the motherboard will need to be replaced.
If it runs for a minute or two then shuts down there is heat somewhere causing problems with the processor and the motherboard is protecting the system. Check the fans inside the PC, specifically the small one on top of the processor, then the case fans. Also check the power supply fan and see if it is working, if not the heat may be cutting the power supply's power to the PC causing the shutdown.
rmatheson@wowway.com
Sep 23, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Auto shut down problems
Check your Processor FAN and Heatsink lock if the heatsink firmly sit tight on your processor, sometimes the heatsink lock is lossen making the processor extremely heat and shutdowns automatically, if its ok, then try replacing your powersupply.
Jun 11, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
51 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
