Question about Dometic Rooftop RV Air Conditioner
My rv has a ac but no thermostat only swicthes on the macine to control it. on witch circuit can i install a thermostat
  • Dometic Master
  • 43,501 Answers
You can install a t-stat on the A/C side of the on/off switch...
Just make sure it is a line voltage t-sta and that the t-stat and wiring are heavy enough to handle the amperage of the unit...
heatman101
Posted on Aug 26, 2010
Ac compressor wants to run with the thermostat turned off?
Either your thermostat is shorted or the primary wiring to the contactor is shorted or even a stuck contactor.
Good luck,
Marty
Aug 24, 2014 | Dometic Rooftop RV Air Conditioner
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Replacing the remote control for rv ac/furnace with standard thermostat
You are aware that the ceiling assy (control box) will most likely need to be replaced as well, to work in conjunction with new thermostat. If you contact dometic ( www.dometicusa) and give them your model number off bottom of roof unit and what thermostat you are trying to install, they will advise what is required.
Oct 17, 2011 | Dometic Rooftop RV Air Conditioner
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
We have 1 ac & rv is ducted for a 2nd. How hard is it to install?
Normally all wiring required is in the 14"x 14" hole, and installing upper (roof) & lower unit (controls) is very basic. I would confirm what I have in way of wiring available before I start. Some manufacturers will run thermostat wires & hydro to the area, others will only run hydro, which leaves you to run your own thermostat wires, or use ceiling controls on unit.
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Thermostat in motorhome quit working
try removing power from t-stat and leave off for one minute and power back up see if resets
Nov 23, 2008 | Heating & Cooling
Thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
26 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
