Question about Sony Ericsson W910i Cellular Phone
Call key, end key & clear key do not work. Unable to make a phone call
  • Sony Ericsson Master
  • 17,130 Answers
Possibe accumulation of dirt in the front panel or damage to the pad switches. You will need to open the phone and check on the board, clean and set them , use some methy spirit to wash carefully the accumulated dirt . check the specified pads carefully for any damage to the tracks.
If this wont help must confirm if the interface IC is defective.
Posted on Aug 26, 2010
Testimonial: "thankyou I will try this "
2 Suggested Answers
  • 308 Answers
SOURCE: my cell phone call/end call,option & clear key is not working
software fault best thing to do is flash the phone with new software.
tutorial: http://forums.se-nse.net/topic/39748-tutorial-flashing-a2-phones-with-a2uploader/
Posted on Apr 18, 2010
What can i do log onto facebook and titter? it keeps saying unable to log onto.....
Reboot phone & then try, if that doesn't work (cures most nokia smart phone probs) then reset the account in (email & accounts)
nobody tells you this but you should power off your smart phone at least once a week to clear the memory & reboot it, it is just a little computer & gets clogged up now & then, with batterys lasting so long no 1 turns them off anymore & so much is running in the back ground that it just cant handle it anymore rebooting it sorts all that out.
Apr 04, 2015 | Nokia N9
How to clear a full mailbox on a uniden 6.0 phone
Here is Uniden's online link: http://www.uniden.com/index/home.cfm
Mid page you'll find a spot to look for the owner's manual to your phone.
In the event the book fails to offer any help or "how to" instructions to remedy your problem, and you are still unable to clear your mailbox entries, contact your cell phone provider for tech support. The problem may be on their end.
Mar 18, 2015 | Uniden Lands Phones
How to reset sanzo zio phone
WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
8. Allow the phone to completely reboot. This may take a few moments.
9. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
Dec 02, 2011 | Sanyo Cell Phones
How to reset cricket zio
a)
b)
Procedure, cont.
NOTE: If you receive a self-test screen or blue screen, the hard reset was done incorrectly. Please try again, from step 1.
Dec 02, 2011 | Cell Phones
My kyocera sanyo cricket phone screen is locked how to unlock it
Hard Reset.
1. Turn off the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
Phone is completely reset as if it came out of the box. You'll need to *228 and reload ALL of your data.
or WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
a)
b)
Procedure,
Sep 12, 2011 | Kyocera Zio M6000 Cricket
Up,right and clear button not working when opened
i have the same problem on my phone and i was unable to fix it but i could get the clear, up, and left buttons to work by sliding the screen down a tiny bit until the buttons on the screen light up (they are not lit up when the phone is slid out). you won't be able to push the top row of keys, but by sliding the phone slightly down you should be able to use the clear, up, and left keys
Jul 23, 2010 | Samsung Sway SCH-U650 Cell Phone
My cell phone call/end call,option & clear key is not working..what will i do??
Apr 05, 2010 | Sony Ericsson W910i Cellular Phone
Unable to enter program mode for Sharp AR-C260M Copier / Printer
Solved the problem by switch on press #P Then * then C then *  then 14  This will then ask if to execute the action to clear the service code H5-01.
Will need to ensure that the fuser unit is not causing a blockage on the feed out path as this code is caused by 5 errors / misfeeds in the Fuser unit.
Nov 13, 2009 | Sharp AR-C260M All-In-One Printer
Phone is frozen
Hello everyone I have great news. To clear the out of range error code just remove the handset from the base, hold down the end key and the # key at the same time. It will say deregistered completed place the phone on the base. Your problem is solved. Enjoy!!!!!!!!!!!!!!!
Apr 18, 2008 | Lands Phones
Sony Ericsson W910i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
