Hi Fault Code F22 Please - Washing Machines
  • 92 Answers
Can't understand
Posted on Aug 26, 2010
Maytag dryer 3000 fault code f22
Replace the door latch. Fault code F22 is for the door latch.
Oct 12, 2015 | Maytag Dryers
I have bosch classixx 6 washing machine with F22 code flashing ?
How to reset Bosch Classixx 1400 Express
hi,couldn't find too much detail about the fault , may be faulty brushes an commutato......the abovel ink gives details and how to reset after f22 message
good luck
r
Jul 09, 2015 | Bosch Washing Machines
What does f 22 code mean
if you could tell me the make & model I could tell you what the code fault is f22 applys to 8 different makes of machine and they all mean different faults
Dec 02, 2011 | Washing Machines
Keep getting F22 I removed lower front , found door release, opened door I cleaned catch, removed and checked impeller Checked electric connections under the hood Still get F22 code
You likely have a faulty door lock assembly, which is what this fault code is telling you. Most often caused by a faulty switch within the lock assembly itself, you will need to replace the entire assembly. The part is available HERE .
Jan 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Maytag 3000 series dryer fault code f22. what does it mean? dryer is just over a year old so i think i'm outside warranty.
F22 is an exhaust blockage. Machine shuts off to prevent overheating and causing a fire. Check the exhaust in the back for blockage. Also clean lint screen before each load to decrease the chance of exhaust blockage
Oct 03, 2010 | Maytag Dryers
What does F22 error mean?
This fault code denotes 6 failed attempts at locking the door. I have found that this code is typically indicitave of a failed lock. Check the strike on the door to be sure nothing boke on it, and if not get a replacement door lock assy for your machine. You will see the three screws that hold it in and can remove the front spring clamp from your door boot to give yourself access to the door lock.
Good luck to you on this!!
Jun 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he5t
this looks like a classic whirlpool control board issue. fault is a communication error between board and panel. check connections.
whirlpool always recommends replacing both at same time. very common problem.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
F22 code appears on Kenmore Elite Front Load washing-?
communication error between control board and panel. Make sure both are replaced together. common problem
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
