I can not remove the soap drawer to wash it up?
  • 92 Answers
Maybe its blocked by something please double check then call an engineer
Posted on Aug 26, 2010
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water leaking out of soap dispenser?
Mar 17, 2013 | Washing Machines
Simpson front loader washer leaking from front soap drawer on the spin and rinse cycle when filling
Mar 10, 2013 | Washing Machines
I need to remove a drawer front for cleaning.
If this is a front loading washing machine..................Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
If helped, click.
Mar 02, 2013 | Refrigerators
WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
Mar 14, 2011 | LG WM2277HSW XL Front Load Stackable...
The powder will not dispense. Water is getting in because the powder is wet and clumpy but is still left in the dispenser.
I suggest you remove the soap dispenser drawer and thoroughly clean it, ensuring that the outlet at the back of the drawer where the water and soap feed into the machine are completely clear of any soap buildup.
Before you replace the drawer, ensure that the water feed into the drawer (this is a pipe or tube above the drawer slot) is not clogged with soap.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The fabric softner is not draining during the cycle
Normally caused by undissolved soap residue. Switch off machine from mains, Remove detergent drawer from washing machine, there might be a small plastic clip that need to be levered by hand before the drawer can come out completely. Soak detergent drawer in a tub of water, rinse under tap and wash thoroughly until all soap residue has been washed away. Replace drawer.
Jan 15, 2011 | Frigidaire ATF6000ES Front Load Washer
SOAP DISPENSER HOSE
take both star screws from under lugs on either side of the lid remove that then take soap drawer out if screws are not visable remove front facia panel the same screws which hold the facia will also hold the soap drawer in place as you lift the drawer you will be able to undo the hose to the drum.
Mar 08, 2008 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
