Question about Car Audio & Video
I have an alpine iva-d105 and when I bring the volume up to 17 to 20 or so while playing a cd with lots of base or no base at all the hu shuts down and starts back up again an will do it again and again at same volume range. Volume bcan go higher with ipod conected before it seldom shuts down.
  • 3,037 Answers
It's common for the voltage source at the radio to be weak. Thin wiring and corroded connections create resistance in the power wiring, which results in a voltage drop when the deck's amplifier requires more current.
The easiest fix is to run a new power and ground wire directly to the battery from your radio. Depending on the length, some 14-gauge or 16-gauge speaker wire should do nicely. Connect the deck's black wire to your battery's negative terminal, and the yellow wire to the positive terminal. Put a 10-amp fuse on the wire near the positive terminal.
If your deck is wired to turn on and off through a key switch or accessory switch, then leave the deck's red wire connected as it is now; it doesn't require any significant current. Otherwise you can combine the red wire with the yellow wire and connect both to the positive terminal.
Let me know if you have any further questions
good luck
Posted on May 06, 2008
I have no sound when I play a DVD/CD on my Alpine IVA-D105 head unit. Butbi do have sound when I use the tuner....
Disconnect whatever you have connected to the solid blue wire in the Alpine plug, and re-connect it to the blue/white wire instead.
Jul 14, 2015 | Alpine Car Audio & Video
IVA-D310 PLAYS DVD'S BUT NOT CD'S!
As last resort you might try a firmware upgrade if available. Otherwise the unit needs to be replaced since laser mechanism has lost the ability to focus on and play back cd's. Repair not cost effective so ..............
Aug 26, 2017 | Alpine IVA-D310 Car DVD Player
I cant watch video on the alpine iva d100
Sometimes they have a setting on video head units that only allows you to play video when the parking brake is on, try that and see if it works.
Nov 12, 2009 | Alpine IVA-D100 6.5" Wide LCD w/DVD/CD/MP3...
Hello to you i currently own the alpine iva-D105 in my vehicle , my problem is the touch screen doesn't display anything although al of the functions work . my question to you is can i fix this...
Not a very likely scenario unless you have some good electronic troubleshooting skills. Sometimes it is the touchscreen itself, but it can also be the circuitry that drives the touchscreen. Taking them apart can also be a very tricky job. One mistake can cost you lots of extra money at the repair center. It is not a wise thing to try and fix electronics without some knowledge of how the circuits work and without the proper test equipment. I have been repairing car audio systems for nearly 18 years and have seen many people bring in things they thought they could fix themselves and it almost always would have been cheaper for them if they just brought it in to begin with.
Let me know if you need any help.
Jul 14, 2008 | Alpine Car Audio & Video
Alpine
If this occurs with the head unit plugged directly into the amp (no signal processors inline, you probably have open shields on the head unit.
To check the shield ground, disconnect all RCA cables from the head unit and measure the resistance between the RCA shield on the head unit and the case of the head unit. It should read ~0 ohms.
Dec 03, 2007 | Car Audio & Video
Can't view the movie
it isn't bypassed properly. recheck bypass wiring.
Sep 13, 2007 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Car Audio & Video Logo
75 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
