Question about Hotpoint WMA64 Front Load Washer
Water coming out of door seal and won't stop even when machine turned off
  • 92 Answers
Maybe pipe broken :? ?)
Posted on Aug 26, 2010
Samsung dishwasher leaking from bottom
Whenever this happens to me, there is food/debris covering the plastic mesh screen that covers where the water exits underneath. It starts dripping because, with it clogged/impaired, the water inside rises slightly and starts leaking out of the bottom front door seal. After I clean up the debis (and sometimes there is debris near/in the drain itself - that's why the mesh pops off so that you can get to it), the leaking stops. I also put a new foam seal on the bottom of the door (just added self-sticking insulating foam strip like you would use on a front door of a house, right on top of the lame seal that was already there), worked great. Good luck.
Jan 25, 2018 | Samsung Dishwashers
LG 1814CW washing machine leaking water
It may be time to replace that door seal again
May 07, 2014 | Washing Machines
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Cistern
The arm controls the Flush Valve. Inside the flush valve is a black rubber "seal" that closes the end of the fill pipe and stops the water. If a piece of sand, grit, or small rock gets imbedded in the seal it will allow water to pass through even when the tank is full. Either you take apart the flush valve and remove the grit, or you replace the whole valve. Sometimes even when the grit is removed the rubber seal is damaged and must be replaced. A new valve, and some of these replacement seals can be purchased at a good hardware or plumbing supply store. Use the valve handle, below the tank, on the pipe that comes through the wall, to turn off the water before replacing the seal or valve.
May 26, 2013 | Home
Hotpoint washer/dryer wd440 door wont open stopped mid cycle
  • Disconnect the washing machine from the mains supply
  • The door seal is held in place on the door frame by a thin metal clamp band. This band is held in place at the top of the door seal with two plastic halves that clip together. To remove, insert a flat bladed screwdriver between the two halves and gently lever or prize them apart and then unpeel the door seal from the door frame
  • Remove the soap dispenser drawer
  • Remove the timer knob and control panel
  • Undo the 3 screws that were behind the control panel and the 3 screws at the base of the front panel under the door
  • Remove and carefully place the front panel to one side
  • The pressure chamber bottle is attached to the bottom of the tub at the end of the small rubber tubing coming from the door interlock. Remove it and thoroughly clean it out, paying attention to the small hole where the rubber tubing is attached
Warning: The pressure system is how the washing machine controls the water levels. Disturbing it can cause water leaks, or even overfilling and flooding if the job isn't done properly.
Jun 29, 2011 | Washing Machines
Leaks water when washing from the door
It's because of a hole in the door seal body. The water runs down inside the machine and comes under the front of the washing machine
For this first unplugged and then take the top off the washer and there is usually a nut and bolt to undo which is holding a clamp band round the door seal fixing it to the tub.
many cases where the water runs down from the bottom of the door but has in fact come from the soap dispenser but the leak was coming from the door.A thin line of water trickles from the soap dispenser and runs round the door frame to appear as a door seal leak. Make sure this isn't the case.
Thanks.
Kevin
Jul 04, 2009 | Whirlpool Washing Machines
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
WATER COMING OUT FROM DOOR AND DRAWER
On this washer  the seal was replaced ?Did it stop leaking after the seal was put in ? Front load hatch on this is in front area located on the bottom(base).Remove the front  to gain access and you can now reach the pump and  look for any blockage.After  you have found and removed the blockage,run the washer again and if any water leaks remain call your local  servicer .You may have a bad front boot (seal) or its just loosened and it need to be re- tightened.Any water leak should be repaired ASAP so you dont have even more damage to the machine and your home.If the repairman cant stop the leak on his first visit than have the Boot replaced on his second visit.
May 24, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
26 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
