Question about HP DeskJet 6122 InkJet Printer
Greetings - have a full black cartridge yet prints green?
    Genius:
  • 1,044 Answers
Clean the print-head by going to the maintenance in the properties of the printer. Go to Control Right click printer and click maintenance on the drop down menu. Also ensure that the cartridge is seated properly.
Posted on Aug 26, 2010
Get the esp 2170 to not print light green instead of black ? I keep on replacing cartridge , to no avail !
replacing a cartridge, while the nozzles are blocked won't help.
Realise the printer will mix there colours to get "black" on the paper. So even a full cartridge, can't make the other colours black till the blockage is gone.
Please try this. If you have ink cleaning fluid, (only for printer ink) use that, if you dont have cleaning fluid, use clean water.
Open the printer as if you replace a cartridge. Remove the black one and look tot the bottom of the cartridge holder. There is a little pipe, where the ink should go in. put some drops water or cleaning fluid in there leave it a few minutes. with a tissue dry it and again insert some drops of water or cleaning fluid. Then put in a cartridge and give the printer a black and white print job. Like print a few A4 papers. Let it print till the black comes back. Can take up to 4 pages A4. I hope this will unblock the nozzles.
Please even if you don't need to print, switch the printer on at least once a week. And even better, let it do a bit of printing every week. This will save a lot of frustration.
Dec 03, 2014 | Kodak ESP Office Equipment & Supplies
My Dell 2135cn printer is printing Black when I'm calling for green. The color cartridges are full
If cartridge that has the blue & yellow (combinds for green), is low or out or clogged or defective, printer will automatically print black. Get some hot (almost boiling) water, then take color or all cartridges out of machine, put in container with about 1/4" of the hot water and let set for awhile. Do not put entire cartridge just the bottom where the print heas is located. The take paper towel and gently remove residual water from water. Replace, do print clean cartridge on your printer.
Edwin
Oct 11, 2014 | Dell 2135cn Color Laser Printer
This printer uses all 4 inks to make black by default. You have run out of magenta in the color cartridge. Go to printing preferencies, Color tab. Check Print in Grayscale and tick "Black only" to disable color use.
Aug 14, 2010 | HP DeskJet 6122 InkJet Printer
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Yvonne
Aug 09, 2008 | Office Equipment & Supplies
Does not print black
Most likely you have no black cartridge installed or it is empty causing your printer to use the colour cartridge for black. But if your colour cartridge has 1 colour which is less full than the others it causes black to become greenish or sometimes reddish depending on which colour is less. A new cartridge or a black cartridge will solve the problem.
Aug 08, 2008 | HP DeskJet 825c InkJet Printer
Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
PROBLEM WITH EPSON STYLUS C86
hey generaly if you dont have any one of that two cartridge then it wont allow you to pring so you need both cartridge in their position
but it is not necessary that both cartridge will be in working condition
so if you want only black and white prints you just need black cartridge in working condition and one colour cartridge in its position even if its empty then also it works but if you dont put colour cartridge in printer it wont allow you to print through black also
Mar 28, 2008 | Epson Stylus C86 InkJet Printer
Print Out
yes replace the cartridge it appears the cartrige is defective
Dec 06, 2007 | Dell 924 All-in-One InkJet Printer
HP DeskJet 6122 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
