Question about Ford Compact Tractor Water Pump Fits 1500 1700 1900
Have a ford F1900 tractor and the water pump has siezed. i replaced it about 10 years ago with a water pump for a car which uses the same one and is about 40 bucks but cannot remember what kind of car it was from.
    Sergeant:
  • 224 Answers
The water pump from almost any 4 cylinder ford car made in the 70's and 80's will work, but the cheaper one will be from a mid 70's mustang
Posted on Aug 26, 2010
  • Kelly Aug 26, 2010
    and a cheaper one would be from a Ford festiva
My GX126s overheats dealer can not find problem tractor is 2years old and it has done it since new please help
I had an issue many years ago , not on a tractor but may still apply. I bought a water pump for my car. Car still overheated. Turns out the water pump had an obstruction in it. Just maybe your factory waterpump is defective.
May 02, 2017 | Garden
4610 ford diesel tractor water pump bolt torque settings
First you need to know the diameter of the bolts and the type of thread ie 3/8 N/C or 5/16 N/F then look at the type of bolt ie plain steel or high tensile SAE grade 3, 4, or 6, once you know this go to a general purpose bolt torque chart, and derive the torque spec info.
If the water pump is cast iron use the full torque specification.
If the water pump is alloy then reduce the torque spec 10%
Below is an example of a general purpose bolt / nut torque chart
May 05, 2016 | Ford Cars & Trucks
What year is my Ford 4000 tractor serial number is C466846?
go on line to ford tractors and find a page that will get you the information.
Jul 18, 2014 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Do you have step by step instructions for replacing the water pump on a Ford 2000 tractor?
I would like to know how to chane a water pump in my ford 2000 tractor, what would be the best way to do this?
Jun 12, 2011 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Ford 5000 Tractor 3-point doesn't go up but the hydraulics work
This can get a bit complicated, and not for the faint of heart.
I have seen this in a lot of older tractors Generally it is a poppet valve inside one of the spool valves
These systems operate at 1500 to 2200 PSI
I had an Oliver 1755 that we tried everything new O rings the works until I had on old neighbor tell me to replace the poppets - under high pressure the nylon ball which had split would seperate and not allow fluid to pass then under high pressure it would push back together and you honestly could not see that it had broken
$ 12 bucks worth of new parts and it works like a dream In the past 10 years I have seen and fixed more than 20 old tractors with the same issue/solution
Mar 12, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Not put antfreeze in my tractor
If you don't use anti freeze the pump seals will harden and you will be replacing the pump every 3-4 years.
Feb 01, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
99 ford taurus is running hot. No water leaks,
OHV engine. I have seen these wear the blades off the waterpump. Does the heat work.
Jun 28, 2009 | 1999 Ford Taurus
Ford Compact Tractor Water Pump Fits 1500 1700 1900 Logo
159 people viewed this question
Top Ford Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Ford Tool and Hardware - Other Expert? Answer questions, earn points and help others
