Question about Canon PowerShot A1100 IS Digital Camera
It is not connecting to my computer...i have windows 2007, when i plug in the usb cable it is not reading
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Jun 08, 2011
EFI/Mircrosoft/Boot/BCD
It's not clear what exactly you mean. Generally, you don't connect two computers together using a USB cord. You can use a "cross-over ethernet cable" to connect the network jack of one computer to another computer. This allows transferring files and/or sharing an internet connection. If you have a wireless router you can enable Windows "File and Printer Sharing" on each computer and transfer files that way. Please provide more details of what you're trying to accomplish by connecting the computers together with a USB cable, and we may be able to give you a more specific answer.
Jul 30, 2014 | E-Machines eMachines Desktop PC
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Need an operating Manual for a 1T omega portable hard drive USB 2
There should be no need for a manual for a USB 2 External Hard Drive. Simply plug it into a USB Port on the Computer and select it with Windows Explorer. Basically, It will assume a Drive Letter other than C: or D: dependent upon how many drives you computer has. A Tower with a CD Read Only drive and a CD or DVD burner drive will have C: primary Hard Drive, D: typically assigned to the read only drive and E: CD or DVD Burner drive. Windows explorer will display all Connected Drives. If it doesn't show up there it is probably a fractured wire in it's cable or a damaged contact it the USB connector on the cable.
Nov 18, 2011 | Iomega Computers & Internet
How to connect to a pc
Install the software first, then connect the usb and power cables, then turn on the unit.
Here is a section of the installation manual :
Software Installation
1. Do not connect this device to computer yet.
2. Insert the utility CD into computer's optical drive, and then the installation window should
automatically appear on the screen. If the installation window doesn't show up, go to "My
Computer" and browse the CD. By executing the "index.html" file, the installation window
will appear.
3. Click on "Private Folder Manager"/ "Playlist Manager", and then follow the on screen
instructions for installation.
4. After the software had been successfully installed, see [Connecting to USB] for cable
connection.
Connecting to USB
1. Connect the plug of AC adapter to the connector marked "DC IN", plug the other end into
an electric outlet.
2. Connect the USB cable to the USB connector. Then connect the other plug to computer's
USB port.
3. Press the Power switch and then the blue LED will light up.
4. The computer will detect this device and you can start accessing the drive.
Jul 13, 2011 | Argosy HV372T Mobile Video HDD Media...
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
My computer not reading device1430 magellan
assuming your using a windows xp or 2000 os, try another cable if you have one..turn the gps off, plug in the usb cord and restart the gps. if that fails, if the cable is connected to a port on the front of the computer,move the usb cable to a rear port on the computer and try the previous way i just explained.
if those fail, disconnect all usb devises connected to the pc and restart the computer and try again. (always use a rear port on the pc if you can)
Aug 09, 2009 | Magellan RoadMate 1430 GPS Receiver
I have a 2wire 2071 - A modem and it wont read my ethernet cable
First check device manager to see if the copmuter recognizes the card, if it dont use the add hareware app, and have windows plug &play try to locate it. then open the case and remove the card with windows running and replace it in the slot , P&P may then locate it if windows doesnt, then the ethernet card may of had a voltage spike go thru it and fried the card.
Jul 12, 2009 | Computers & Internet
Computer with Windows Vista suddenly can't find
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 07, 2009 | Canon PowerShot A560 Digital Camera
Usb cable has never worked to transfer pictures to computer
It could be a bad USB cable or a bad port. You can test the port by plugging in a different device. If the port tests good and the camera is connected and turned on, you most likely have a bad cable.
Jan 13, 2009 | Kodak EasyShare Z710 Digital Camera
Connecting my new PIXMA MX700 to my computer
Please read your owners manual.
It's very simple to connect a printer, and ever simpler to read the part of the manual that tells you how.
Perhaps you should get a friend to help you. If I say "Power Cord" and "USB Cable" will you know the difference? If not, I probably couldn't explain it to you through type.
If you think you could tell them apart, then do this:
1. Make sure you have a USB cable. Most printers don't come with a cable to connect to a computer. If yours did, you'll have two cables in the box. The USB and the Power cables.
If you don't have a USB cable, you'll have to go buy one.
2. Put the CD into your CD ROM drive, follow the instructions. When the computer tells you to, plug your USB cable into the back of the printer and the computer. Plug the power into the printer. Turn the printer ON.
The computer should detect the printer. Follow the instructions on the computer screen.
That should be all there is to it.
Dec 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PowerShot A1100 IS Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
