Question about Bosch Evolution 800 B20CS80SNS Stainless Steel Side by Side Refrigerator
The frezzer side doesnt get ice cold it stays around 28 -30 i have it set on -4
  • Bosch Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My samsung side by side was working great untill
You have an automatic defrost problem. The refrigerator is not defrosting
Three important parts. It probably is one of these.
Defrost Timer
Defrost thermostat
defrost heater.
The fan is probably fine, but has nothing to do with Defrost
Check the heater continuity and change the heater defrost thermostat
then replace timer if those don't solve it.
Leo Ponder
imufo2@sbcglobal.net
Jul 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
Side by side, refrigerator not cooling well. go it turned to coldest setting. freezer works great
MAKE SURE THAIR IS NO ICE ON BACK OF FREZZER WALL THE FREZZER CONTOL SHOULD BE SET IN THE CENTER LIKE 4 OR C
Jan 31, 2010 | Refrigerators
Fridge not cold enough set at 8
okay if it is not cold enough you should check the frezzer temp, and then play around with the fridge that should help. I had the same problem
Aug 08, 2009 | Master Bilt Indoor Step In Cooler 70""W x...
Where is the deforst timer on my maytag
Some units are different. Some are located behind the temp control unit, others located up inside top of unit behind the panels. There is usually a diagram on the back of your fridge
Jul 09, 2009 | Maytag MZD2666K Side by Side Refrigerator
Frezzer and refrigerator work sometimes
  1. check rear wall of freezer for ice build up, if so unit is not defrosting
  2. check to see if fan is running in freezer
  3. check to see if compressor is running
Nov 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Bosch Evolution 800 B20CS80SNS Stainless Steel Side by Side Refrigerator Logo
44 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
