The machine is a Canon Pixma 610. paper won't feed through and keeps coming up as paper jam, but we have cleared paper from all sources but the paper pulls in so far and then jams again, but we can't see any blockages anywhere. We have cleaned the rollers as well. Any help would be appreciated.
For hard to reach jammed paper I cut a 1” x 11” piece of 11pt synthetic paper. Then notched a series of V’s into one side. It’s a very effective tool to feed through hard to reach areas of the paper path and clear jams. I chose synthetic paper since it’s extremely durable and won’t tear off and contribute to the jam issue.
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
- new cartrige for Black ink - can scan - can photocopy documents BUT can't print documents from my MacBook eventhough the paper feeds and goes out at the other side
Clean The Paper Feed Rollers Using The Unit's Operation Panel
Ifthe paper feed roller is dirty, paper is not fed properly because thepaper feed roller slips. Cleaning the paper feed roller could resolvethe paper feeding problem. Please follow the instructions below toclean the Paper Feed Rollers directly from the unit.
Caution:Since the cleaning process wears down the paper feed roller, performthis procedure only when necessary and no more than three (3) times.
Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
Tocheck if the rollers are clean, load a sheet of Letter-sized plainpaper in the same paper source you selected in step 2, and press the<Open> button.
Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source. Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Sourcesetting in the printer driver. If the option is not set to 'Paper FeedSwitch', paper will feed from the source selected in the driver.
hi there, This problem mostly caused by another material (such as broken paper, etc) present in paper path prevent paper to reach paper cam sensor. Check inside your printer and clear paper path from another material. You can also try to clean paper feed roller. If problem still persist, replace paper feed roller Regards
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
