Question about Philips 60P8342 60" Rear Projection Television
My Philips 60P8342 TV wont turn on
My Tv stopped turning on. at first it would work fine but couldn't turn it off had to unplug it. now it wont turn on.
  • Saul Gonzalez
    Saul Gonzalez May 07, 2008
    no it doesnt
  • Saul Gonzalez
    Yes i checked all three and they all seem right. Yesterday it turned on like normal but couldn't change channels but i was able to turn it off. Now it wont turn on again.
  • Philips Master
  • 8,617 Answers
Does the led blink or is it constantly solid? Let me know cause if its blinking thats an error code.
Posted on May 06, 2008
  • Sonny Berry
    Sonny Berry May 07, 2008
    your problem is related to the standby voltages. thats why the led doesnt light or flash. have you checked the fuse?
  • Sonny Berry
    It sounds like a solder or loose wire connection. try looking at all the wire connections and make sure they are all connected tightly and if that doesnt solve the problem you should then look for bad solder on the circuit boards. bad solder appears to be dull grey and not shiny. Let me know how you make out after checking the items above.
SOURCE:
How do you discharge a rear projetion tv before doing a service on it to avoid getting shocked. I'm getting ready to put a new signal board in my philips 60".
The SSB (signal) board will be fine after allowing the set to be unplugged. Dangerous voltages will be stored on the main input board and LSB ( deflection) but the signal board will be fine.
Jun 01, 2011 | Philips 60P8342 60" Rear Projection...
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
Power problem
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
0667c5f.pngSOLUTION
Its a fairly easy DIY job. Check the site www.TvRepairKits.com
Their kits include a photo instruction guide, parts, email/phone support, etc.
Dec 02, 2009 | Philips 60P8342 60" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
  • Dull looking video
  • White looking video
  • Red/Orange looking video
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Tv turns off by it self
Ours 60" (60P8342) turns off after a short period of time also. My husband researched it online. The cheap solution he was told to try is to unplug the TV (or plug into power strip and switch off) when you are done watching it. A computer board inside over heats and it's a protection mechanism for it to turn off. Otherwise, it's over $100 to fix the computer board.
May 29, 2008 | Philips 60P8342 60" Rear Projection...
Reaccuring problem
The main fuse, it should 5A/250V. The one you bought is 0.5A/250V and it will burn because it can not handle the amount of current that passes through it.
The other fuse that sparks even when the TV is unplug because is the charge of a capacitor that circulates when you place the fuse.
Just curious why you had to change the fuses?
Mar 06, 2008 | Philips 60P8342 60" Rear Projection...
Philips 60p8342
Probable bad sensr inside tv.....Philips part is no longer available
part # 932215244687..................................................T.
Aug 30, 2007 | Philips 60P8342 60" Rear Projection...
I have a 50P8342 with simular problem
My tv was doing some of the same type things I touch one of the manual buttons ont tv and the channel would change or the volume would go up or down. I changed the control board behind the manual buttons on the face of the tv and now it works fine with or without the remote. the part no. is 313501707611 go to sears web site type in this number and order it. this part will come up as 60P8342 but thats ok becouse the 50P8342 and the 60P8342 use the same part number I know I have both models and changed them both using the same part and part number.
Nov 19, 2006 | Philips 60P8341 60" Rear Projection...
Television Turns on and then Turns Right back off!!!
Either a short in the High Voltage section or power supply section. If you are not a TV technician you will have to find a reputable repair shop to help. Good luck.
Aug 01, 2006 | Philips Magnavox 9P6034C 60" Rear...
Philips 60P8342 60" Rear Projection Television Logo
308 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
