Repair of refrigirator
My refrigirator has stop working since 10 days back , still i had not recieved support from samsung
  • Victor Nwachukwu
    Victor Nwachukwu Sep 20, 2017
    take it to a good refrigerator specialist
Buy..new one
Posted on May 07, 2008
Samsung refrigirator water dispenser works without filter but does not work with filter
Not enough water pressure in supply line to get past filter?
Open valve feeding supply line more and see what happens.
Sep 06, 2017 | Samsung Refrigerators
Samsung Refrigirator RS2545SH: Installing my ice maker when I heard several clicking sounds, I realize I forgot to unplug my refrigerator before installing my new ice maker. After plugging back my Ref I...
First lets check the wiring plug under the top left hinge cover to insure the connection is firm and then check connections at the motherboard. Let me know what happens, Thanks Sea Breeze
Samsung Refrigerator Familiarization
Dec 13, 2012 | Samsung Refrigerators
My phone wont send or recieve MMS messages. I restarted it when I first got it and it worked for a few days after that but then it stopped again. Ive tried restarting it and taking the battery out and...
Usually, when a smartphone won't properly send or receive MMS, it's because you have too many messages stored. This is not, however, always the case. Try toggling 'airplane mode' on and then off on your phone. After turning it back off, your phone will reinitialize connections with your carrier. This usually solves my problems.
Aug 03, 2011 | Samsung Infuse 4G Smartphone
My Daewoo refrigirator's freezer is cooling but not the lower com
sounds like you need to replace the ptc overload on the compressor as this component supplies start and run power to the compressor and its getting weak and short cycling the compressor,they just unplug and plug into the side of the compressor and when you remove it shake it by hand and if you hear it rattle thats a good sign its bad
May 31, 2010 | Refrigerators
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
I have a frigidaire electrolux refrigirator sided by side and it just stopped workin one day,then next day staeted again ,it went back and forth finnaly we had to shut it down because our food spoiled...
you need to check the power and make sure the cord is not damage and the outlet is fine.the next thing i would look at is the overload and ptc start switch on the left side of the compressor.there is a small diode in there that might have gone bad also check to make sure it is secured to the side of the compressor.i hope this helped.good luck
Jan 22, 2010 | Electrolux Refrigerators
I have a side-by-side Samsung refrigirator RS24FAMS. There is bad smell coming from the back of it. I took off the panel at the lower back but found nothing suspicious. The smell is not from inside the...
there is a drain pan over there next to the compressor ...the old water get there and dry out ...see with flash light all over you might need to clean it (turn unit off) and do it gently ...good luck use some cleaning spray...
Jan 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Need help
A removable panel in the rear gives access to the compressor and condenser. Remove the panel and clean out the condenser. Make sure the condenser fan operates when the compressor runs. Restore the panel to its original position for normal operation.
May 27, 2008 | Maytag MSD2756G Side by Side Refrigerator
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
