Question about Sta Rite Industries Shallow Well Jet Pumps, 1/2 Hp
Pump cycles frequently - Sta Rite Industries Shallow Well Jet Pumps, 1/2 Hp
  • 8,404 Answers
Your tank needs more air in it ... do you have a air valve standard tank or do you have a tank with a rubber bladder? I suspet the former and your air valve is sticking.
Shut off the pump, drain the tank (which will replace water with air) and then restart the pump.
Thanks for your interest in FixYa.com
Posted on Aug 26, 2010
Dishwasher does not drain
Dishwashers do not drain the water has to be pumped out of them.
If the water is not being pumped out on any cycle then the pump has failed and you either need to replace the water pump (which will be quite expensive) or buy a new dish washer. Pump failure is a pretty common in part because of the amount of debris many users don't rinse from items before placing them in the washer. Also the filters at the base of the washer need to be removed and cleaned frequently and this is often neglected.
If the water is only remaining in the washer for the final rinse cycle but is otherwise being pumped out on the wash cycles, then the issue will be with the electronic control board.
Dec 08, 2015 | Frigidaire Dishwashers
Heat Pump Cycling too frequently?
It should run until it reaches the temp. setting on the thermostat.
Do you have a make and model number so I can assist you?
Jan 11, 2014 | Mitsubishi MSH09TW Air Conditioner
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
FAZ08 window heat pump cycles very! frequently during cooling cycle
Check your room sensor misplaced or fell down. Place it in the middle of evaporator coil. Helpful.
Jan 21, 2011 | Frigidaire Heating & Cooling
Get Flo Message frequently and sometimes FIL2 message.
FLO is related to either a dirty filter or a clogged suction to the pump or possibly a pump related fault. FIL2 is the code displayed when programming the 2nd Filtration Cycle.
Apr 01, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Drain Blockage Error
try cleaning put the pump in the front
the other thing you may have obstruction inside the pipe leading to the pump or away from the pump
coins can get stuck in the pipes and act like a swing valve in the pipe
or your pump may be worn out not pumping water out in programed time
make shure use the right soap powder and dont over suds machine pumps dont pump soap suds
Jan 28, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Incomplete water emptying following spin cycle
your pump is on its way out inside they have a small fan which pushers the water out if that is lose than the pump has to be replaced common fault
Dec 25, 2006 | GE WJRR4170E Top Load Washer
Sta Rite Industries Shallow Well Jet Pumps, 1/2 Hp Logo
88 people viewed this question
Top Sta Rite Industries Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Sta Rite Industries Garden Expert? Answer questions, earn points and help others
