Question about Sharp AR-5316 Advanced Digital Imager Copier
I have sharp copier AR-5320E, its flashing H and 2, Please what can i do to solve the problem?
  • Sharp Expert
  • 257 Answers
Hallow, sometimes power outages causes this kind of a problem. To begin try to reset the code by keying the following:
-Press #, Interrupt, C, Interrupt, Keys in that order. The copier display must go off. Enter 14 and press copy key.
If it reappears, the check this.
This means that the copier thermistor is not working. This may arise if you had removed the fuser unit and did not fix the thermistor connector to its place. Check whether its well fixed to its place or whether its wire is not broken.This may also arise if there was a paper that had jammed and may be wrongly removed forcing it to displace or disconnect the thermistor. Check but if nor , replace another thermistor, its visible once you remove the black cover of the fuser unit and you will see slightly brown component with two white wires. Good luck.
Posted on Aug 26, 2010
I HAVE SHARP COPIER, THE MODEL NO IS AR-5320E. I AM HAVING THE PROBLEM OF H4 ERRO. PLEASE HELP ME
check heater section properly,(thermister,thermostat,heater lamp)go service mode and clear error code also
Sep 20, 2011 | Sharp AR-5320 Black and White Copier
I want to download sharp printer driver AR 5316/5320E
if u ned download manualse and driver softwer see 2 www.givemefil.net every thing is thire
Jan 18, 2010 | Sharp AR-5320 Black and White Copier
I have problem with my digital sharp AR 5320E it is showing CH.
If lit steadily, open door or other interlock. If flashing, developer unit not installed or not connected properly. open and close all of the covers/doors to your machine. you may have a bad switch or a inteloc may be broken. an interlock is a peice that contacts the switch
Dec 28, 2009 | Sharp AR-M237 Copier
I need the software for ar-5320e
I need a share ar 5320e software .How can I get this software?
Jul 16, 2009 | Sharp AR-5320 Black and White Copier
My copier sharp AR-5320E is showing number 2 and letter H on the"
press #
press *
press clear
press *
enter 14
press the start key
Apr 23, 2009 | Sharp AR-5320 Black and White Copier
H2 IS HEATER UNIT PROBLEM.IF SUB CODE IS 00 THEN IT SHOWS THAT FUSER THERMISTOR IS OPEN.USE SIMULTIONS 14 TO RESET IT.PROBLEM WILL BI SOLVED .DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Jan 20, 2009 | Sharp AR-5320 Black and White Copier
My copier AR-5320E is showing a number 4 and letter H
the fuser unit is not heating up
unplug the copier then plug back in
make sure the fuser area where you clear jams is latched down
close all doors
if this does not work your fuser lamp is burned out or a fuse has blown on the heater roller
You will have to call service
Jan 07, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
102 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
