Question about Puzzle Quest: Challenge Of The Warlords for PSP
You have five fives. 55555 now, (i) Arrange the fives to get largest possible value (ii) arrange the fives to get a value equal to 1. (iii) Arrange the fives to get a value less than 1. (iv) Arrange the fives to get a value equal to 56. remember : do not use the signs +.-,x,/ . But a bar or line between two digits can be helpful
5power 5555
Posted on Sep 12, 2010
How to send this back to factory
Do you mean factory default? If so please add details of make and model. If it is a phone with an easily removeable battery it should possibly be a matter of removing the battery and leaving it out for five minutes. If the battery is difficult to remove there should be a method by depressing a combination of buttons.
If you mean actually returning a phone to the manufacturer you should contact them to arrange na RMA
Jun 14, 2015 | Cell Phones
Brand new. worked for five minutes then steam stopped. after another five minutes, started hissing, then water started squirting out of face plate
Recommend contacting the seller customer service and arrange for a replacement or refund. Obviously, do not use it anymore.
Mar 31, 2015 | Coffee Makers & Espresso Machines
How many 5 digit arrangements (combinations) are there using numbers 1 thru 10
There are 252 combinations of ten items taken five at a time.
If the order matters then there are 300,240 permutations of ten items taken five at a time.
Feb 26, 2015 | Office Equipment & Supplies
Vtech cs6649 will not register more than one handset
The errant handsets must be de-registered from their
original base and then registered to your base.
NOTE: the CS6649 handles a maximum of only five
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
In that case, you can clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Jan 09, 2015 | Vtech Lands Phones
How to calculate median ?
Arrange the date in ascending order (sort it). Find the element that is in the middle. If the number of data elements is odd, there a true middle element and that is the median.
If the number of data elements is even there is not one but two middle elements. Take the average of their values, that will be the value of the median.
Now, imagine that a (virtual) data element has been inserted between the two middle elements, with its value equal to the average of the two middle elements.
Jun 28, 2014 | Casio FX-570MS 2-Line Display Scientific...
I would like some help in solving some TVM problems using the BA II Plus calculator. i.e. How to solve: I invested a lump sum of $2400 in an investment that returns 6% annually. How much will the...
2nd [CLR TVM] (clear TVM registers)
2 4 0 0 +/- PV ($2400 initial investment, negative because you're paying it out)
6 I/Y (6% annual interest)
1 N (one year)
CPT FV (compute future value, see 2544.00, the value after one year)
5 N (five years)
CPT FV (see 3211.74, the value after five years)
1 0 N (ten years)
CPT FV (see 4298.03, the value after ten years)
Feb 19, 2011 | Texas Instruments BA II PLUS Financial...
I have five pairs of 8 ohms speakers which i want to connect in serries. what wattage will you advice ?
Why? Amps are designed for specific loads, typically 8-ohms. I'm sure you could arrange several speakers in such a way as to present as close to, say, 8-ohms as possible.
Feb 15, 2011 | Behringer EUROPOWER EP2500 Amplifier
How to create play list/arrange music in T Sonic 840 MP 4 player
Sorry. You can not create or arrange playlist.
Creating playlist option is not there in T sonic 840.
Cheers...!!!
Apr 01, 2009 | Transcend T-Sonic 840 MP3 Player
Puzzle Quest: Challenge Of The Warlords for PSP Logo
497 people viewed this question
Top Puzzle Video Game Consoles & Games Experts
Andrew Taylor
Andrew Taylor
Are you a Puzzle Video Game Console and Game Expert? Answer questions, earn points and help others
