Question about Refrigerators
User manual for Ocean FFC 61/48 for one of my customers.
I have bought a Ocean Upright Freezer second hand and it came without a user manual, just wondering what is the best setting for it?
See if you can download a manual for it and get the recommended setting. Or just experiment with the knob and wait for a day to take the temp and adjust it accordingly.
Jun 19, 2017 | Freezers
Where can I download user manual for Ocean washing machine?
I would try one of two options.
First, I would find the model number on the machine, and then type that number in to the proper box on the website of "SearsPartsDirect".
There should be the option to order it from them.
If not, I would type "Ocean Washing Machine" in to the search box on your computer, and try to find a dealer that could sell you the manual.
God bless your efforts.
Oct 24, 2016 | Washing Machines
How to fix C3100 Scanner carriage problem ?
Hi.
C3100: ISU home position error
It usually means the scan carriage can't move.
If it s a little MFP, you can unlock the scan with the yellow button on the left of the glass (under the DP). (This was only meant for transport reason).
Otherwise - Possible cause:
Defective FFC between CCD PWB (YC1) and control PWB (YC8).
- Replace the image scanner unit (ISU)
Defective FFC between control PWB (YC6) and scanner PWB (YC103), or improper FFC insertion:
- Reinsert the FFC. Also check for continuity within the FFC.
If none, remedy or replace the FFC.
Defective home position sensor.
- Replace the home position sensor.
Defective harness between ISU motor and scanner PWB (YC104),
or improper connector insertion.
- Reinsert the connector. Also check for continuity within the connector harness. If none, remedy or replace the harness.
Defective ISU motor.
-Replace the ISU motor.
Mar 16, 2016 | Kyocera Office Equipment & Supplies
Fatal error 1a39
Fatal error 1a39 - The description says:
"Service Call Error
Code: 1A39
Category: Hardware
Error Name: Head Error
Cause:
• Connection failure of the HEAD FFC.
• Electric parts or components are damaged due to improper HEAD FFC connection such as connecting it at an angle.
• The drive circuit in the PRINT HEAD is damaged.
• The fuse of the MAIN BOARD has blown.
Check Item:
Is the HEAD FFC connected properly without being connected at an angle and any abnormalities such as peeled terminals?
Remedy:
1. Replace the HEAD FFC. (See P.127)
2. Replace the PRINT HEAD. (See P.126)
3. Replace the MAIN BOARD. (See P.111)
As a point of reference, your three manuals are here (link below), which is where I found this info. (See the first manual listed - in the chart on page 53: Table 2-2). Good luck!
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=220056&prodoid=63096219
Aug 20, 2014 | Epson SureColor T-Series T3000 Inkjet...
Ocean netbook keyboard has frozen, can't do anything
Before it drives you mad, you may want to consider selling it or putting it back in the cupboard. Try here for a User Manual: http://www.oceantechnologysystems.com/user-manuals/ From what I have read on-line, your not alone.
Apr 16, 2013 | Computers & Internet
Gateway MX3215 - how do I change usb ports (2 on left side). My son had something in each port and the laptop fell off the bed, pulling the working part of the ports out. Where can I get repair manual and...
This issue unfortunately, is a hardware issue and not just a minor issue. Laptops have USB ports embedded to the motherboard and replacing just the USB ports means replacing the motherboard. If the computer is still under warranty, you might want to contact Gateway and don't call in for repair but to get an Accidental Damage Protection. Why? Because I don't think it is covered by the base warranty that you have on your computer. However, if the computer is no longer under warranty, you then have to get it repaired, and pay for the repair. The repair cost might make you decide to just purchase a new computer. Motherboard costs around $250 - $300 to replace.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 22, 2011 | Gateway MX3215 Notebook
How do i remove and replace my keyboard for satellite a205 laptop
Agree with LaptopRepair. The procedure for Keyboard removal is pretty close.
Wanted to add information on the FFC connector though.
If you have never dealt with a Flat Flex Cable connector, you are going to be in the dark, and could break something.
1) The flat cable from the Keyboard to the motherboard, is a Flat Flex Cable.
2) The connector on the motherboard the FFC connects to, is an FFC connector.
3) The Flat Flex Cable removes FROM the FFC connector.
> Just the flat flex cable, comes out of the connector on the motherboard.
Again, The flat cable by itself comes out of the connector, with no connector on it.
4) The FFC connector on the motherboard, does not come away from the motherboard. It is attached to the motherboard.
The FFC connector on the motherboard does not come apart in two pieces.
It opens to release the flat flex cable.
The FFC connector ONLY opens so far.
(1/8th inch ?) It is a two piece connector, but does Not come apart.
Looking at the FFC connector, you will spot a parting line going across the middle.
The top half of the connector looks like a fat T.
The two tabs on either side at the top of the Top half, make the T head shape.
These two tabs are pushed towards the LCD screen.
Ease one tab up a little, then ease the other tab up.
This opens the connector, and allows the flat flex cable to come out.
Install the flat flex cable from the New Keyboard, in the same direction as the old Keyboard's flat flex cable.
One side of the flat flex cable has exposed copper strips. (Contacts)
The other side does not.
Be sure to install the flat flex cable of the Keyboard in the correct orientation.
Do not rate this information. Just added info.
Oct 28, 2010 | Toshiba Satellite A205-S5879 Laptop
I want to replace my keyboard for my toshiba satellite P505
Sep 01, 2010 | Toshiba Satellite P505-S8945 Notebook
I've lost the assembly instructions for the Fisher Price Ocean Wonders Aquarium Cradle Swing.
Download the Ocean Wonder Aquarium crib attaching infant soother manual here http://bit.ly/sLkjFG
May 25, 2010 | Fisher Price Ocean Wonders Aquarium
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
