Question about Car Audio & Video
Hooked up camera system wrong
Hooked up a deisel audio rear back up camera backwards and burned up fuse/filter on power/ground wires. Can i just eliminate the fuse/filter box and just install a fuse on power wire?
  • 26 Answers
Yes. should work the same.
Posted on May 09, 2008
I hooked up my pioneer stereo and have no sound. Checked speakers and fuses I don't know what's up! Help me!
check wires from stereo to speaker by using a 9 volt battery on two wires to the back rt and a light bulb,then do two wires to rear lft ,then do the front,you may have polarity backwards,use black as ground
Apr 28, 2015 | Pioneer Car Audio & Video
Keep breaking fuses on T/L Ctsy after my son hooked a power wire there for his amp. now it keeps breaking fuses.whut can i do to fix this.
it sounds like the power wire you Son hooked up is not grounded and keeps blowing fuses. Try grounding that wire and make sure its not touching any others to spark and burn out fuses.
Oct 14, 2011 | 1991 Chevrolet Suburban
I'm trying to install a new battery in my 1984 Nissan Sentra. When I hook up the terminals, the wiring starts to smoke leading me to believe that the hook up is backwards. What is the correct hook up for...
Hi and welcome to FixYa, I am Kelly (Electrician since late 1960's)
Ground goes to the - pole. Hooking it up backwards can damage your alternator, wiring harnesses and fuse links. (Fuse link damage is a nightmare to sort out!) What you do by hooking up a battery backwards is turn your vehicle wiring harness into a giant heating element. (<-Very bad!) If you just changed the battery and then you hooked up the cables with the smoking cable result you certainly did connect the cables backwards. The ground cable... will connect to chassis and in most cases the engine body / transmission somewhere.
The positive cable will eventually connect to the starter. Follow the ground lead from the battery to the chassis or engine body connection. (metal to metal contact) Once your sure that is the ground cable; connect it to the - post of the battery AFTER connecting the positive post terminal.
If you have a newer audio system you will have lost your radio codes. We can not provide the codes for anti-theft reasons. Activation Codes must be from the car dealer or audio system retailer.
Thanks for choosing FixYa,
Kelly
Feb 27, 2011 | Nissan Sentra Cars & Trucks
I've hooked up the back up camera to the cameras input and connected the power wire to the back up lights. I'm getting power, but I don't see an option for the camera in the menu nor does the camera come...
i don't know exactly what system you are using
from what you stated your saying the monitor is powering up when put car into reverse
but the camera is not coming on
what this tells me is either the camera it self not getting power or ground
u hooked up the video wire between monitor
the camera needs to get power some how it might be the wire that hooks into monitor but i don't think so usually that just the video wire (but depends on system)
i assuming there is one or two more wires on the camera itself that needs hooked up
a power wire
and a ground wire if there no ground wire then frame where camera is mounted to on car needs to be cleaned of all rust and paint
I assumed allot if this don't help you at all please let me Make and Model # of your camera system and i try and help you more
Nov 16, 2010 | Car Audio & Video
Fuse
It depends on how long you had the battery hooked up backwards but check for any ground wires/straps from the engine to the frame or body that are burned in to.
Feb 09, 2009 | 1997 Dodge Dakota
Kenwood 9102d wont power on
YOu might have burned out the inner fuse. Better yet the source connect...
Nov 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Kenwood KDC-MP202 sound turns off when headlights are turned on
just solved a similar problem on my car i bought a Cd/dvd player for my 2000 concord lxi i hooked it up and hooked a rear-view camera and it worked perfect but wen i turned the headlights on the cd player shuts of so i disconnected the orenge wire that came out of my cd player from the orange on the aftermarket harness then grounded the ping wire (rear con wire) it worked fine but i couldn't see any footage from the camera for that i bought a long red power wire and hooked it to the red camera power wire that hooked from camera to reverse light and took the other end of the new wire i bought and hooked it to the orange wire that came out of the cd player now every thing works fine. you probably dont have the right power to run both cd and head lights thats why you need constant power to run both just hook up an extra wire between a positive wire to the orange dimmer wire its simple;
ground to ground (black)
12+ positive to 12+ positive (red)
and an extra wire (usually a red 18 guage wire bought mine at walmart) to the dimmer wire from the back of the cd player (orange) edit.gif
Mar 21, 2008 | Car Audio & Video
Kicker ZX1500.1
Set your multimeter to DC volts. Place the black lead on the ground terminal of the amp. Place the red lead alternately on the B+ and remote terminals. Both of the terminals must have 11+ volts. If the voltage is low on either of the terminals, follow it back to determine why the voltage is low. If the voltage is low on both of them, you may have a bad ground.
The ground needs to be connected to the floorpan of the vehicle. Scrape the area down to bare metal before boltting the ground lug to the floorpan.
Dec 23, 2007 | Kicker ZX1500.1 Car Audio Amplifier
Car Audio & Video Logo
116 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
