Question about Casio Parts Cash Register PC Desktop
E94 keeps coming up on my til - Casio Parts Cash Register PC Desktop
  • Casio Master
  • 1,749 Answers
It sounds like you have a Casio with a printer that can't turn. Make sure there is nothing jamming the printer.
Posted on Aug 27, 2010
I have an error code of E94 on my intex portable spa what does it mean?
If alarm code E94 is displayed on the control panel, it means the water temperature is too low. If alarm code E94 appears, unplug and plug back in the GFCI/RCD and test the GFCI/RCD to restart the system when the spa water temperature is higher than 39?F (4?C).
Jan 25, 2016 | Intex Pool & Spa
Electrolux time manager 7kg washing machine keeps stopping mid cycle and has an error code E94
E94 means: "Console control problem. Replace control board."
However fault codes are not absolutes. They simply tell a service person where to look for a problem. For example, if i was a service man and i had a control board like yours on the truck i would switch it out first to see if it solved the problem. If it did i would charge you for the part and labor and be on my way, even if it was just a loose wire or connector that was causing the problem. Or if i was a washer warranty rep and the machine was under warranty and you said you were getting an E94 fault code i'd ship you a control board and consider the problem solved.
I am not a service man or a warranty rep so my advice is to wiggle the wires going to the control board. Also, disconnect then reconnect any plastic conectors you see. Let me know.
Jan 30, 2013 | Electrolux Washing Machines
I went to use a Casio 120 CR-B and it keeps saying E94 and no matter what i do, nothing happens. What is the problem as I don't have a Manual?
E94 means printer failure. Check for paper jams or any reason why the printer can't turn. Otherwise, there is a common problem in the sensor on these printers so it may need a repair.
If anyone needs a Casio 120CR / 120CRB manual, c-tech has them here: http://the-checkout-tech.com/manuals/cashregisters/casio1.php
Dec 22, 2010 | Casio Parts Cash Register PC Desktop
Sir good evening i have cash regester casio 160cr.Error code is e94 pls help how i can run my cash regester thanks.
I suggest you to reset your equipment.Here is how:
Remove AA batteries and unplug register from wall for 15 minutes.
Two more options;
Option #1:
To print the transaction details before clearing the journal memory:
VERY IMPORTANT: Do not interrupt once printing begins or the journal will not be cleared.
1. Make sure the paper is full in the register.
2. Turn to Z mode.
3. Hit the RC key until the screen displays "E94".
4. Hit Cash Amount Tender.
Once the printing is completed, the journal is cleared and the register is ready for use.
Option #2:
To clear the journal memory WITHOUT printing the transaction details:
1. Turn to Z mode
2. Hit RC key until the screen displays "E94 Clear"
3. Hit Cash Amount Tender
Nov 27, 2010 | Casio Parts Cash Register PC Desktop
I have an old CASIO 120CR-B cash register, which just keeps coming up with E94 all the time. There is no paper jam, and impossible to set the time & date in PGM, as it also blocks with E94, so unable...
E94 is definitely a printer failure message, so if you can't find a paper jam, then the printer has a sensor problem or possibly a broken gear or changeover coil. In a budget machine like that one, the printer is usually replaced, but it costs half the price of the machine, so it may not be worthwhile.
If anyone needs a manual for a Casio 120CR or 160CR, there is one here: http://the-checkout-tech.com/manuals/cashregisters/Casio_120CR_and_160CR_users_manual.html
120CR-B and 160CR-B http://the-checkout-tech.com/manuals/cashregisters/Casio_120CR-B_and_160CR-B_user_manual.html
Sep 28, 2010 | Casio Parts Cash Register PC Desktop
E94 error keeps coming up, even if there is no paper in machine and then disables machine
If you can't see any paper jams, try gently turning the gears on the side as best as you can (don't use a sharp object to turn them or you may damage some of the teeth). If the printer is jammed, then that is your problem, otherwise, it may have motor failure or a sensor problem. It may be time to take it to the dealer.
Jun 16, 2010 | Casio Parts Cash Register PC Desktop
I've got a 160cr-b casio til, it says i've got an e94 error, but i haven't got any paper jammed....any help?
Then you have printer failure. They use the tiny Epson 42 series printer which does not have a long life as it is the cheapest model. It needs to be looked at by a dealer, but don't be surprised if the printer needs replacing. -----------------------------------------------------------------------
If anyone is looking for a Casio 160CR manual:
http://the-checkout-tech.com/manuals2/cashregisters/casio1.php
Mar 01, 2010 | Casio Parts Cash Register PC Desktop
Error code E94 paper jam
I used compressed gas duster to clean the resgister and it worked. It is called Duster Destroyer and I got it at the Staples for $9.99
May 30, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
