Question about HEWLETT-PACKARD Compaq Presario CQ61412NR Notebook PC
I default it and suddenly erase - HEWLETT-PACKARD Compaq Presario CQ61412NR Notebook PC
  • 8,404 Answers
Reinstall the printer ... that will fix your problem ...
Posted on Aug 26, 2010
How can I restore the default wallpaper on my kin onem?
Reset your phone to factory default. Please follow the following steps.
Steps to Reset Phone
The Erase Phone Data process will set the preference settings to factory defaults.
  1. From the Home screen, select Settings.
  2. Select About Your Phone.
  3. Select Erase Phone Data.
  4. Select Ok.
Mar 15, 2011 | Cell Phones
I dont know the pass code...?
the simplest way is by restoring the default configuration and then reconfigure the passcode.
You can erase the
current configuration and restore factory defaults in two ways:
• Use the Erase function of the router (see “Erasing the Configuration” on page 6-7).
• Use the Default Reset button on the rear panel of the router. Use this method for cases when
the administration password or IP address is not known.
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
If the wireless router fails to restart or the power light continues to blink or turns solid amber,
the unit may be defective. If the error persists, you might have a hardware problem and should
contact technical support.
Dec 25, 2009 | NetGear WGR614 Wireless Router
Lg dare touchscreen not working all of a sudden.
possible cause, you may be accidentaly drop it, or seat on it...
first if it has it manual keypad, then use it and try to set on factory setting default.
Default security code..12345 or 1234
see if it works but beware , all your personal profile might erase, but before doing it try to remove the sim card and memory card.
if it still not work then bring it to cellphone technician, there is a possibility that the flex (tape wire type) or the black crystal(small IC part)migh be damaged
Oct 29, 2009 | LG Dare VX9700 Cell Phone
Erase All button is grayed out on my Canon Powershot SD550
Okay. You can try resetting the unit to factory default. But I just want to warn you that this will delete all settings on your camera.
To RESET it to factory defaults, all you have to do is go to the Tools menu. This is the hammer and wrench tool I guess. And then hit Reset All.
Aug 15, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
How do I reset the security code to erase all
Menu - Settings and Tools - Phone Settings - Security
Enter Lock Code (By default last 4 digits of phone number)
Under security select Restore Phone and press OK.
You will be prompted to permanently erase all user data & reset settings to factory defaults.
Highlight yes and press OK.
Re-enter the lock code and press OK.
Jun 16, 2009 | Motorola Cell Phones
Intuos 3 Pen/Stylus suddenly stopped working (as in dead).
Will the tablet work with the mouse? If it does not, is not working is the blue LED light on. If the LED is not working try another usb port. If the mouse works go into the Wacom tablet properties from the start menu. Select the grip pen from the tools. Click on the default button to restore the stylus to factory settings. When you press the pen you should see the pressure scale rise. You can also test the eraser pressure. You could also replace the stylus tip to see if that works. From the Wacom site you can order a new stylus or tips if it is found defective.
Apr 14, 2009 | Computers & Internet
The erase button does not work for incoming or sent messages
i have an envy one and this happend to me except my phone wouldnt erase anything. if you turn your phone off "and leave it off for a few mins" then restart it it should beable to erawse messages
Jan 22, 2009 | LG enV VX9900 Cellular Phone
All the songs erased all of a sudden. How to fix it.
If you did a reformat or a firmware upgrade, it will erase all of your songs. The only option is to reload them all.
May 19, 2008 | SanDisk Sansa e260 MP3 Player
Erasing all phone numbers and user information on A650
FROM THE MANUAL
ERASE MEMORY
Erase memory erases your Phonebook and Voice Dial recordings. This feature is useful if you want to give your phone to a friend or family member.
1. In standby mode, press the left soft key (Menu), then press 9 (Setup), 4 (Security). You're prompted to enter the lock code.
2. Enter the lock code (try the last 4 digits of your phone number unless you set a different one), then press 6 for Erase Memory. A confirmation prompt appears in the display.
3. Use the navigation key to highlight Yes or No, then press OK. A confirmation message appears in the display while your messages are being erased. Your phone then returns to the Security menu.
RESET PHONE
Reset Phone returns all setup options to their factory default.
1. In standby mode, press the left soft key (Menu) then press 9 (Setup), 4 (Security). You're prompted to enter your lock code.
2. Enter the lock code, then press 7 for Reset Phone. A prompt appears in the display asking if you wish to restore default settings (except for the Phonebook and Voice Dial).
Feb 05, 2008 | Samsung SCH-a650
How to reset the cisco switch to factory default?
When you say you were able to connect to the switch through hyperterm, were you able to login with the enable password? If not, you cannot reset the factory defaults without the enable password. If you do not have this then search on Cisco's site for password recovery for your model switch. If you did login with the enable password, the command to run for CATos is "clear config all". For Cisco IOS, you have the right command with "write erase". When you issue that command, do you get a "Erase of nvram: complete " or an error? Are you issuing the "reload" command after a successful erase? Be sure you answer No when it asks "System configuration has been modified. Save? [yes/no]:" as sometimes this seems misleading and some people think they mean to save the reloaded default. They are really warning you that you are about to loose the old configuration and attempting to prevent you from accidently erasing it. So answer "no". After a successful reload of the IOS you should also clear any VLAN information. To do this, issue "delete flash:vlan.dat" and then do another "reload".
Aug 29, 2007 | Cisco Catalyst 3560-24PS Switch
HEWLETT-PACKARD Compaq Presario CQ61412NR Notebook PC Logo
13 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
