Question about Ricoh Aficio 220 Laser Printer
Basically when the Ricoh Aficio prints anything out the toner just lies on the page and will not stick. you can wipe the toner off with your hand. Does anyone know what this problem might be and how to solve it?
  • ajcaddoo Aug 26, 2010
    Yes the wiping off is consistant across the whole page. It was working fine this morning and then i noticed a clicking/cruncing sound and then after a few more prints it started to occur. If it would be possible to send the part numbers thre is a possibility i may take it apart. thanks
  • 1,110 Answers
Probably not much you can do yourself....as there are 2 possibilities here. First there is the possibility that you have lost fusing pressure. The fusing unit in this machine using a combination of heat and pressure to "fuse" the toner onto the paper. You may have broken a fuser frame which is a common problem on the 220. This cause the fusing rollers to loose their pressure against each other and thus stop fusing. This usually causes poor or no fusing more on one side than the other. You might want to let me know if the toner wiping off is consistent accross the entire page.
The other possible cause is your thermistor set is bad. The thermistor reds the temperature of the fuser rollers so the machine knows when they are up to the proper temperature for fusing. I some circumstances I have seen them go bad and always register to the machine that the fuser is hot enough when it is not.
Either way you are going to have to be comfortable with removing the fusing unit from the machine and then dis-assembling parts of it in order to repair it. If you are interested in trying this you can reply to this post and I can at least give you the part numbers you might need depending on what you find.
Good Luck and Thank You for using Fixya.
Posted on Aug 26, 2010
  • Edwin Martens
    Edwin Martens Aug 26, 2010
    go to www.precisionroller.com
    At the upper right is the search box. Search for J3762, not the Ricoh part number but their part number. This will give you a picture of the fuser frame section. I am giving you this part number because if you described a noise along with the problem then that clearly points us towards the fuser frame failure and not the thermistors.
  • Edwin Martens
    If you need anything else you can find me by searching for wheatland services
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
Ricoh aficio 2075
R u using original toner? if no, replace ori. if yes, r the hot roller in the fuser hot enough? is there any gap between hot roller and pressure roller? toner smear can only be caused by non ori toner or faulty fuser unit. Faulty developer can cause sandy print out
Mar 22, 2014 | Ricoh Office Equipment & Supplies
Missing print
machine needs drum and developer, but a temporary fix would be...open front door near notice green handle where toner is replaced, look to the right of green handle and down about 2 or 3 inches, you should see a plastic or chrome cover the size of a postage stamp, remove the cover and you should see a 3/4 inch wide piece of glass barely sticking out, carefully grasp the glass and pull it out of machine, wipe the toner off the glass , put glass back in and replace cover , shut front cover and run copies .
Jan 30, 2014 | Ricoh Aficio 2015 Copier
I am looking for thresdhold when the Ricoh aficio sp c420dn printer sends out the toner low message. Is it 15%? I cant find this anywhere. There are other Ricoh models also.
Ricoh sense toner in the following methods:
Toner Near End
To detect the toner near-end, the machine uses:
Pixel count (memory chip on the AIO)
AIO rotation distance (memory chip on the AIO)
Toner End
To detect toner end the machine uses:
Output from the TM sensor (center)
After near-end, it is estimated that 200 pages (A4, 5% coverage) can be printed until toner
end occurs.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 01, 2011 | Ricoh Aficio BP20N Laser Printer
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
Ricoh Aficio 1232C prints with red-violet tone
download the RPCS driver from the Ricoh support site and then when you will install the driver go to preference then user settings and adjust the contrast and other options until you get the color of the printed image as you wish to be
Dec 14, 2009 | Ricoh Aficio 1232C Color Copier
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh 1045 only printing on 1/2 page
When you put the delveloper did you:
remove the cover to install it.
remove all of the old developer out of the machine.
Did you go into service mode and run sp 2-801.
Jun 30, 2008 | Ricoh Aficio 1035 Copier
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Toner lines when I print
I don't think it is anything to do with the toner cartridge as this doesn't put the toner on the page seems to me that the drum unit is faulty either the cleaning blade has failed or the charge roller. Best thing to do is call a service engineer or copier company that deal with Richo or Rex Rotary.
Thanks J
Nov 18, 2007 | Ricoh Aficio 180 Laser Printer
56 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
