Question about Acer TravelMate TM5720-6337 NoteBook, Intel Core 2 Duo T7500, 15.4" Wide XGA, 2GB Memory DD
I have 512 K memory chip ,can I add this to my travelmate 6492
  • 17 Answers
I do not know your specific model of laptop, but if the above specifications are accurate, then most likely not. Most laptops have two DIMM ports, where you place the RAM. This laptop probably has two 1gigabyte pieces already installed. This means to add yours, you must remove one and replace it, thereby decreasing your RAM to 1.5gigabyte total. Now under the rare possibility that your computer has a single 2 gigabyte RAM installed, then yes you can really easily. Just open up the panel on the back with the RAM inside and check. If only one is installed, then install the other (you can use google search to find the exact process), and your computer will be ready to go. I hope this helps, -Robert
Posted on Aug 26, 2010
Which webcam driver will be good for window 7 on my acer travelmate 5744?
install the chipset first sir, the install the cyberlink 3rd party application afterwards. you may get all of the drivers on this link :
http://us.acer.com/ac/en/US/content/drivers thanks and happy troubleshooting!
Oct 16, 2013 | Acer TravelMate 5744-6492 : 2.4GHz Core i3...
Windows 7 running slow after memory upgrade
If it's Windows 7 32bit it has limits on the amount of ram it can use.
Google it and see.
Jan 31, 2012 | Dell Precision Workstation 670 PC Desktop
PC RAM
This refers to the data width and chip configuration. 64*8 is an 8 chip 512MB module. (8 components @ 64MB each) 32*8 is an 8-chip 256MB module. (8 components @ 32MB each), etc.
Mar 03, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
Has anyone upgraded the memory on a toshiba satellite 1900-603
it should be beneath the slot u installed the memory on both slots are next to each other one on top the other beneath i fu dont find it tell me exact model number to help u more in this
Feb 24, 2009 | Toshiba Computers & Internet
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Purchased more memory from 256 to 512 the tech that installed the memory installed the 512mb DDR 2100 and left one of the 128 chips installed to give a total of 640mb ram receive error message "out...
Run Registry Editor (Regedt32.exe).
2. From the HKEY_LOCAL_MACHINE subtree, go to the following key: \System\CurrentControlSet\Control\Session Manager\SubSystems
3. Select the Windows value.
4. From the Edit menu, choose String.
5. Increase the SharedSection parameter.
For Windows NT:
SharedSection specifies the system and desktop heaps using the following format:
SharedSection=xxxx,yyyy
Add ",256" or ",512" after the yyyy number.
For Windows 2000, Windows XP, and Windows Server 2003:
SharedSection uses the following format to specify the system and desktop heaps:
SharedSection=xxxx,yyyy,zzz
Increase the zzz number to "256" or "512."
Best Of Luck!!
Jul 21, 2008 | Gateway Computers & Internet
Continual reboot with second memory module
Your memory isn't an exexact match. The 512MB you have in is probablyis Kingston, part # KT3311/512, PC2100/2700, 512MB DDR. You should get Kingston part # KT3311/1G, PC2100/PC2700, 1 GB DDR. You can use another manufacturer but everything must match exactly execpt the size of course. The speed, DDR, everything. Make sure you have the new chip seated correctly and in all the way first. Of course if it doesn't match the specs of your other chip it won't matter. Best thing to do if buying locally is take the first chip with you. If not buying locally, have it with you when you order to make sure it matches.
Mar 29, 2008 | Toshiba Satellite P35-S605 Notebook
Acer TravelMate TM5720-6337 NoteBook, Intel Core 2 Duo T7500, 15.4" Wide XGA, 2GB Memory DD Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
