Question about HP Compaq Presario CQ50-110US Laptop
I have a compaq presario that seems to get too hot and cause problems. The fan is also quite noisy. Do you think it needs a new fan?
    New Friend:
  • 81 Answers
Laptops stands with Usb port avaialbe in market attached these stands with your laptops it will reduce heat of it.
Posted on Dec 31, 2012
    Genius:
  • 1,044 Answers
There is nothing wrong with the fan. Please go to a computer technician and check the coolant inside which require to maintain the temperature. Over the period it gets evaporated/dried up. Also make sure the air vents are clean and th computer is used in a place where there is sufficient air flow.
Posted on Aug 26, 2010
Compaq Presario S 4150. Noisy fan!
you need to change it before it gose bad it is going now slowly jim
Apr 17, 2011 | Compaq Presario Fan
Fan motor is noisy and loud. Also, the laptop freezes often and must be reboot or restored
I believe your fan is not doing its job. You need to clean the case out (compressed air) and try it. Actually, since you are having that problem, I'd go for a new fan. What you seem to have is a heat problem.
Oct 19, 2010 | Compaq Presario 700 470024-192 Notebook
I recently had a new power supply installed in my compaq presario SR1318NX, now the fans run almost constantly. The air from the fans does not feel hot, nor does the tower. Is this serious?
In a desktop computer the fan is supposed to run constantly otherwise the processor would get that hot the system would repeatedly shut down or even damage the processor or motherboard.
If the fan is noisy then chances are that the fan blades need cleaning of dust.
Other than that you have nothing to worry about.
Regards.
Dec 02, 2009 | Compaq Presario 5000 PC Desktop
Fan noisy
Two common factors why CPU fans are noisy:
1. The collected dusts under your fans.
2. Your computer is running over the neutral power that your Power supply can handle, i.e. overclocking, high graphical games and videos.
solutions:
1. clean fans (power supply fans, exhaust and others)
2. replace CPU fans with branded and proven to be quite fans.. it may be an additional cost but proves to be very silent. :)
Nov 05, 2009 | HP Compaq Presario SR2023WM PC Desktop
Compaq Presario fan is not functioning. It is - fan is plugged into the motherboard but the fan will not run - causing my laptop to overheat - I cannot find a fan controlling software that is compatible...
sounds like a burnt up fan so you might just want to take it to your local computer tech have them replace the fan and put some new cpu compound in their and it will never over heat again
Aug 06, 2009 | Compaq Presario Fan
Fan has stopped working
Go to http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodTypeId=321957&prodSeriesId=3466274
Download the Service Manual. It will walk you through the disassembly process. You can easily install a replacement fan assembly yourself.
Good luck.
Feb 07, 2009 | Compaq Presario Notebook
Compaq laptop screen is black, fan isn't running but the power light is on, do you think its the processor? or what
if i have to pay for it forget it...i thought it was foc as it states "solve your problem for FREE" and no i haven't solved the problem
Nov 19, 2008 | HP Compaq Presario 2200 Notebook
Compaq presario v2000 overheating issues...
Yes, this is a fairly common problem with the v200o, caused by a lack of good fan airflow. Your best bet in using it would be to get a laptop pad. This will not only keep your laptop cooler, it will prevent your legs from blocking the fans when it is on your lap.
May 08, 2008 | Compaq Presario Notebook
Noisy fan..
y dont u try to clean the fans by a vaccum cleaner or something like that. Also some of the screws might be loose, due tu jerks ,try to tighten them up.
Jan 24, 2008 | Compaq Presario Laptop
Presario 2200 CPU fan appears to be dodgy
Not really, since the fan is controlled ny a thermal sensor on the Motherboard. You may want to start by having the fan and heatsink assembly replaced.
Jan 10, 2008 | HP Compaq Presario 2200 Notebook
HP Compaq Presario CQ50-110US Laptop Logo
259 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
