Question about E-Machines eMachines Desktop PC
Won't connect to the Internet
This is a T5246 used with a dial up connection. The system will not connect to the Internet. In checking with the ISP the connection is good. In going through troubleshooting, identified Ethernet adapter local area connection, tunnel adapter local area connection *6 and tunnel area adapter *12 idntifying media status if "media disconnected". Also in checking the local IP address identified "transmission failed, error coe 1231". In having some people check this they think the modem is defective, but this is a new computer less than 6 months old.
  • 81 Answers
If you are using a dialup connection, the ethernet connection would not have anything to do with your problem. Be sure the cable is plugged into the line socket. Take a repular phone and plug it into the telephone socket on the computer and see if you get a dial tone. Be sure you have entered the number correctly including a 1 and area code if required. You may want to call the number your computer is trying to call to see if you hear modem tones ( to be sure the number is correct). If all that is in order, your friends are probably right and your modem is bad. It may be covered under warranty.
Posted on May 09, 2008
CANT ABLE TO CONNECT DIAL UP CONNECTION
Turn on your computer. Click the Start menu, go to the Control Panel and access "Network and Internet Connections." Click the "Create a New Connection" option in the upper left corner of the window. Click "Next" until you reach a list of options. Select "Connect to the Internet," and click "Next" again. Select "Set Up My Connection Manually," and click "Next." Select "Connect Using a Dial-up Modem," and click "Next." Enter a name for the new connection you are creating (e.g. "Dial Up Connection"), and click "Next." Type in the phone number you will be using to connect to the Internet, and click "Next." This phone number will be provided to you by your ISP. Enter the username and password provided to you by your ISP. This will successfully configure your Internet connection. Plug a phone line into your computer's dial-up modem. You may now use the newly-created connection to connect to the Internet. b> Macintosh Computers Turn on your computer. Access the Apple menu and click "System Preferences." Click "View," and access the "Network" option. Click on the "Show" pop-up menu and find the "Internal Modem" option-or the "Configure" option if you are not running Mac OS X 10.5-and click it. Click the "Configure" menu if you are running a version other than Mac OS X 10.5. If you are running version 10.5, select the "PPP" tab. These options will both have the same result. Enter your information into the appropriate fields in the new window that appears. Your ISP username goes under the "Account" field, and password under the "Password" field. Save your preferences when you are finished. Plug your phone line into the modem jack on your computer. Your computer will now be able to connect to the Internet via dial-up.
b>
Feb 06, 2013 | Acer Aspire Computers & Internet
Internet interface trying to reestablish the connection.
what about that no. is this the no. of ur service provider, if not then have u added the right service provider no. in the connection setting.
if not. then add that specific service provider no. and delete all others.
regarding ur case of dropage isp, check then modem or lan which one is used by u.
regards,
Jul 27, 2008 | Computers & Internet
How to do a PPPoE connection?
You have not mentioned OS you are using, i am assuming that you have windows xp or later. Go to properties of my network places and click on create a new connection > Connect to Internet > connect to broadband that requires user name and password .. follow next steps as appears it will install PPPoe protocol and will make a connection also
Jun 26, 2010 | D-Link DFE-530TX+ Fast Ethernet PCI...
I just brought a dell 10' netbook and i have dial up phone service so how can i get the internet on my netbook with dial up service?
Here is the internet setup info for that netbook from Dell's website ...
Setting up Your Internet Connection To connect to the Internet, you need a modem or network connection and an Internet Service provider (ISP).
To set up an Internet connection with a provided ISP desktop shortcut:
  1. Save and close any open files, and exit any open programs.
  2. Double-click the ISP icon on the Microsoft® Windows® desktop.
  3. Follow the instructions on the screen to complete the setup.
note.gif NOTE: Have your ISP information ready. If you do not have an ISP, the Connect to the Internet wizard can help you obtain one.
If you do not have an ISP icon on your desktop or if you want to set up an Internet connection with a different ISP:
Windows Vista®
  2. Click Start interne3.jpg ® Control Panel® Network and Internet.
  3. Under Network and Sharing Center, click Connect to the Internet.
The Connect to the Internet window appears.
  1. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect:
    • Choose Broadband if you will use a DSL modem, cable TV modem, or satellite modem.
    • Choose Wireless if you will use a wireless connection through a WLAN card.
    • Choose Dial-up if you will use a dial-up modem or ISDN (Integrated Services Digital Network).
note.gif NOTE: If you do not know which type of connection to select, click Help me choose or contact your ISP.
  1. Follow the instructions on the screen and use the setup information provided by your ISP to complete the setup.
Windows® XP
  2. Click Start interne6.jpg ® Control Panel® Network and Internet Connections.
  3. Click Set up or change your Internet connection.
  4. Click Setup. New Connection Wizard window appears.
  5. Click Next. Choose Connect to the Internet and click Next.
  6. Click Set up my connection manually and click Next.
  7. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect.
And here is the link to where the info was found...
http://support.dell.com/support/edocs/systems/xlob/dtg/en/internea.htm#wp1012333
and another with more info on that netbook ..
http://support.dell.com/support/edocs/systems/xlob/dtg/en/index.htm
Apr 06, 2010 | Dell Inspiron Mini 10v Netbook Computer
My wifes laptop is trying to use DUN instead of network cable
Open up Internet Options (from the Tools menu in IE or right-clicking the desktop icon and selecting Properties, or through the Control Panel). On the Connections tab, select 'Never dial a connection.' When you want to connect to your ISP you will be required to manually start the dial-up connection.
Apr 14, 2009 | Computers & Internet
Problem with dial up connection
Are you system settings enabled. It has taken me 5 months to find as to where they were. My bio system is software. Certain windows features were not tuirned on, like TCIP and its variations.
SMPT and its variations were in an off state. But I am using a dedicatd line now, and do not need dial up.
Feb 10, 2009 | Sony VGN-CR520E/R VAIO Notebook - Sangria...
How to install raspppoe connection in vista
The trick with XP also woks eith VISTA too.
Try the following in vista, you will succeed.
If you're using a RAS / PPPOE connection for Internet, and wish to automatically connect to your ISP at startup, you may use Rasdial utility which is built-in.
Usage: Open a Command Prompt window and type:
Rasdial <connectoid> "username" "password"
This would initiate a dial-up/PPPoE connection to your ISP.
You can create a batch file with the above parameters and place it in your Startup folder, so that vista dials to your ISP automatically at every startup.
If you don't prefer to enter the password in the batch file, use the following command-line (vista will prompt you for a password - secure)
Rasdial <connectoid> "username" *
NOTE: Type Rasdial.exe /? in the Command Prompt to learn more about this command, it's other parameters.
Hope my info helps you,
Thanx for using fixya,
Cheers.
Sep 27, 2008 | Microsoft Windows Vista Home Premium with...
Internet explorer cannot diplay the webpage. I am not connected to the internet, but all my connections are hooked up correctly
A couple of questions pls:
  1. how are you connected, DSL or dial-up?
  2. if it is DSL, wireless, cable, two-wire/telephone?
  3. what is the brand of your modem?
  4. do you use a router?
  5. what is your machine, a laptop or desktop?
  6. what is your operating system?
  7. who installed the system?
  8. who is your ISP and what is your subscription/package (speed of connection)?
  9. have you tried calling your ISP?
Hope you post back additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 20, 2008 | Computers & Internet
Cannot connect to internet via Actiontec M1000 (Qwest)
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router, other than that you need to check the routers settings, like the password /username for your ISP connection and assuming you originally set it up using an RJ45 lan cable (supplied) before using the wireless.
Aug 23, 2008 | Dell Wireless 2350 Router
E-Machines eMachines Desktop PC Logo
80 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
