Cat 5 wiring
Can I use a cat 5 cable to run 2 phone lines and an internet service? Spiltting the wires in a wall plate with rj11 and rj45?
    Scholar:
  • 60 Answers
Yes you can but depending on the length of the cable, you may not be able to have a connection speed of more than 100 mbps because of the 48V phone line running along the Ethernet link. You have to understand that this is completely outside the structured networks guidelines... but it may be quite useful if you have a lack of cables. So, do that only if you really cannot add another wire without having to destroy you walls or ceilings.
Use the blue and brown pairs for the phone and green and orange pairs for the Internet. Be sure to untwist the pairs as close as possible to the connect point. For that kind of setup, I recommend you to use a BIXed wall plate such as the Belden AX100344 (2 ports) or AX100352 (4 ports).
For the Ethernet outlet, the orange and green wires would go exactly where they should: 3,4,5 and 6.
If you are using a 2 ports plate (AX100344), the blue wires will go into 1,2 and the brown will go into 3,4 of the second outlet. This will make your phone outlet carry the 2 phones lines. Some business phones actually support receiving the two phone lines like this.
If you are using a 4 ports plate (AX100352), exactly as with the 2-port plate, the blue wires will go into 1,2 of the second outlet. Then, the brown wires will go into 3,4 of the third outlet. This way, the second and third outlets will have regular phone lines in which you will be able to plug any kind of domestic phone. Unfortunately, the forth port will remain unused.
This being said, I have explained only how to connect the wall side since I don't know anything about where and how the other end is terminated.
Posted on May 07, 2008
Connection
You need the blue with the white stripe and the white wire with the blue stripe.This would be line one for a phone. but if the RJ45 is in use for an Ethernet connection I would not do it, I would just run a new cat 3 wire for the RJ11.
Apr 10, 2014 | Lands Phones
I need the total wiring diagram for camera [8pin rj11]
8 pin RJ45 (8P8C) male connector
at the camera output
LG LVC-CY100NM Color Security Camera with 8-pin RJ45 (and other cameras for the LSP-M1017M Dual Quad Observation Systems by LG)
Pin
Number Pin
Name Description 8 SPK Speaker (Hot) 7 VID Video Out 6 GRN Ground 5 SPK- Speaker (cold) 4 AO Audio Out/Alarm Out 3 VDC 12VDC 2 N/C RS-485- 1 N/C RS-485+ Note: Pin numbers are labled backwards in the manual (corrected above).
The camera is adaptable for use in any composite video application with the use of a balun.
on the output. I had noise-less video and clean audio across a 350 foot run of cat 5e.
Jan 29, 2013 | LG LVCCy100NM Color Security Camera with...
What do I do? I have a cat 5 cable in my house wiring from one floor to another. Had used this to connect internet between two computers. I do not know if this cable will still connect. I have...
http://www.vellemanusa.com/downloads/1/vtlan4gbnlfresd.pdf
you plug one end in "tester" and other end in "remote" and if it's all good and you are testing straight-through cable it should go from 1 to 8 in sequence. short cable is test (good cable) to show you if there is a problem with your unit. Whatever you see with short cable you should see with your cable.
Nov 08, 2012 | Velleman VTLAN4 LAN TESTER FOR RJ45 RJ12...
I have a (like) phone chord and can't find where to put the other end. We have it plugged into the back of the router, need to know where to plug the other end.
Hi
It depends on which country you are in.
It depends what Broadband wiring setup you have.
It depends which type of cable you are talking about (see images 1 and 2 below)
In some countries, the RJ11 to RJ11 cable goes from this device into the phone Socket of an ADSL filter. One RJ45 to RJ45 cable goes from the Router into the Ethernet Socket of the ADSL Filter. Another RJ45 to RJ45 cable goes from the Router to the Computer. The ADSL Filter then goes into the Phone socket in the wall.
You need an ADSL Filter in every Phone Socket that has a telecommunications device attached to it (Fax Machines, Answering Machines, TV Set Top Boxes, games Consoles etc.). The ADSL filter separates Telehone, Voice & Fax Data traffic from Broadband traffic and allows all to share the same phone line with out conflict.
See Network Diagram below.
In some countiries or wiring setups, the RJ45 to RJ45 cable form the Router to the Wall does not need to go via the Phone Socket and can go directly into its own dedicated Ethernet Wall Socket.
If this answer helps you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and helps us explore the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa
IMAGE 1: RJ11 to RJ11 or ADSL MODEM or BROADBAND or TELECOMS or TELEPHONE Cable
virtual_a_4.jpgIMAGE 2: RJ45 to RJ45 or CAT5E or LAN or ETHERNET Cable
DIAGRAM 1: Typical UK Home Broadband Network Diagram
Aug 30, 2011 | Linksys Wireless-G Broadband Router
How do you wire a RJ11 phone jack with cat6 wire??
I assume you are using this configuration to connect a phone and not data outlet.
The RJ11 connector is used for phones and the RJ45 is used for data.
The CAT6 cable has 8 wires and to wire this cable to a RJ45 connector 2 wires on the CAT6 cable are not connected.
Go to this site for a wiring diagram for RJ11 to RJ45.
http://www.google.com.au/imgres?q=rj11+to+rj45+wiring+diagram&hl=en&sa=X&tbm=isch&tbnid=4RlQiCWju6MukM:&imgrefurl=http://ps-2.kev009.com:8081/tl/techlib/manuals/adoclib/aixasync/asycomgd/port128b.htm&docid=zs9vggehEny1kM&w=966&h=680&ei=WWxCTpbYNeL9mAWkpLjVCQ&zoom=1&biw=1016&bih=511
Aug 10, 2011 | Computers & Internet
I want to connect a CAT5e Ethernet cable (with or without a RJ45 connector) from a DSL router to an older computer that only has a RJ11 input. This will be used for DSL internet service only -- no...
The only "outputs" from a DSL-router are:
* RJ-11 telephone-jack, only if the router also supports voice-over-IP,
* RJ-45 Ethernet port (always present)
You need to purchase an internal network-card, to create an RJ-45 port on the computer, and then use the CAT-5e cable to make the connection.
Feb 20, 2011 | Computers & Internet
The ADSL mechanism about conversion of analog signal to digital s
blue bluewhite is primary pair in cat 5 orange orange white is secondary green and red are primary for standard phone line cable which match up to blue bluewhite
Mar 28, 2009 | Computers & Internet
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
HOW DO I CORRECTLY WIRE THIS WALLPLATE TO MY CAT5e CABLE AND PHONE LINE. WHAT COLOR BELONGS TO WHAT?
http://www.ertyu.org/steven_nikkel/ethernetcables.html
this link covers proper pinout for cat 5 cabling. (RJ45). A phone line is RJ11. You can run ethernet cable through a wall and terminate it at a wall plate designed for ethernet (not a standard phone wall plate). You can't use the RJ11 cable currently in the walls for ethernet.
May 02, 2008 | Computers & Internet
Cat5e to RJ11
You wont be able to....You need another NIC...you can Pick one up at Circuit city of best buy for about 10 to 15 bucks.
Nov 04, 2007 | Cat5e Cat 5E Modular Plugs - For Round...
Computers & Internet Logo
333 people viewed this question
David Payne
David Payne
