Question about Maxi-Cosi Baby Gear
The straps on my maxi cosi Tobi car seat wont extend. I think the strap that you pull to tighten the seat is locked in position.
4 Suggested Answers
SOURCE: Maxi-Cosi Tobi Straps not working
I guess that you have perhaps solved your problem now but if not, have you seen this?
http://maxicosi.com/tobi/default.aspx
Hope this helps.
Chris
Posted on Apr 29, 2009
SOURCE: Maxi Cosi Tobi straps locked
hi i had the same problem so i took it back to toys r us where i got it from, they rang manufacture and were advised that they r going to recall them as it is a fault. hope this helps
Posted on Sep 19, 2009
  • 419 Answers
SOURCE: maxi-cosi tobi strap tensioner not working. able
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Posted on Aug 10, 2010
Can you re thread straps on maxi cosi tobi?
Hi
Due to the safety implications of this being incorrectly done it should not be attempted at home. The carseat needs to come in for our engineers to re-thread the harness and ensure it is performing as it should be.
Please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab for your enquiry to go through to the customer care team in your country who can provide further assistance.
Apr 05, 2013 | Maxi-Cosi Tobi Car Seat - Jet Black
Maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.
Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 20, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Is it possible to buy new covers and straps for this seat?
Replacement fabrics can be ordered via your local Maxi Cosi retailer or direct from the customer services department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 60GBP and if purchased direct there is 3.99GBP p+p
Jun 25, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Pulled tensioner on maxi cosi tobi now i cant release it back
Just did it. It took two of us, but only a couple of minutes and no tools (except a table knife) once we'd worked out what the problem was. The reason the strap doesn't thread easily through the slot is that there is a sprung two-part mechanism that needs to be held open. One person threads the strap through while the other keeps the mechanism open.
Person 1:
1) Find the slot under the chair that the strap goes into - turn the seat upside down; it's a thin gap you can feel with your fingertip when you run your finger along the narrow back of the metal strip under the front of the seat (not the base).
2) Remove the metal rod that attaches the grey reclining lever. The rod is about 20 cm long and can be pushed out without tools. Removing this rod seems to make it easier to open the buckle mechanism. When replacing the rod later, you just have to line it up carefully with holes (we used a torch to help us see them)
3) Make sure the strap passes under the metal rod at the bottom of the seat back (you can see how here in a small photo here: http://www.englishforum.ch/attachments/sale-wanted/37565d1327058634-sale-maxi-cosi-tobi-car-seat-9mths-3-yrs-zh-maxi_cosi_tobu_small.jpg)
Person 2
4) Push back buckle as far as it will go (it goes back past vertical easily, then needs another firmer push,
5) Hold the buckle in this backwards position.
6) Insert a table knife (rounded and blunt, not sharp) into the space under the buckle and push back the sprung, hinged plastic part that the knife touches at the back.
7) Person 1 then threads the strap back through the slot, pushing until then end comes out.
8) Tie a knot in the end of the strap so you don't accidentally pull it through again!
9) Replace the metal rod in the reclining mechanism.
10) Done!
Mar 21, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
The straps on my maxi cosi tobi car seat wont adjust they are really tight and i cant slacking it where do you adjust the straps about?
hi
you have to pull the buckle towards you if they are still jammed check where the bottom buckle join the seat body to see if there is anything stuck in there if not i would recommend taking it back to the shop and get a replacement,
i had to do this just 4 weeks after buying mine the straps got jammed and i nearly broke little ones arms trying to get him out!
Oct 11, 2010 | Baby Gear
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How to alter the straps
how to adjust straps in maxi cosi tobi
Jun 16, 2010 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Sep 10, 2009 | Baby Gear
Hope this helps.
Chris
Sep 18, 2008 | Baby Gear
Baby Gear Logo
117 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
