Question about GE EasyCam Webcam
How to install openxava on windows - GE EasyCam Webcam
Cannot install windows
  1. Please identify on which device you are attempting to install windows.
  2. Is it a new device? If so, Windows may have already been installed as it was delivered to you.
  3. If you are attempting to install windows (which version?) on the hard drive after your computer crashed, you need to boot into the setup area of your computer and select your CD or your dvd drive as one of the choices for a boot drive. Your user manual should indicate how you can access your set up area.
  4. Try searching the web for your particular device for answers, if you cannot find your user manual.
Aug 25, 2014 | Computers & Internet
How to install windows xp on probook 4510s
Installing Windows XP
This is generally how your format the hard disk and installWindows.
First you need a Windows XP installation CD and the productinstallation code, which is printed on the Windows label on the bottom of yourlaptop.
Boot up with the Windows installation CD start and follow the instructions toinstall Windows.
Next Delete the existing Windows partition.
Next Create a new partition.
Next format this new partition - Format the partition in NTFS not a quickformat. This will prepare the Windows for a clean install.
Next create a User(name) and company name (normally Home is all you need).
Further into the installation, you will be required to put in the Installationcode.During the final stages of installation you need to createan User or Users that will use this computer.When you finished installing Windows you need to install thelaptop's device drivers. You need to use a computer with Internet access todownload these drivers from the laptop manufacturer's WEB site and installthese drivers on your laptop.
Next connect a LAN cable to the LAN port from your computer to your DSL orcable modem and you need to Activate the Windows installation on the MicrosoftWEB site.
Next up need to upgrade Windows from the Microsoft WEB site including Servicepack.
Next you need to install your programs
Jun 02, 2012 | HP Computers & Internet
Sir, i am using windows 7 ultimate. i would like to install another one operating system (i.e) windows xp professional. now i insert the win xp professional disk into it but the install windows xp is...
boot your computer with windows XP cd. it will install winXP automatically but remember to install windows XP other than the drive where your win7 is. for examp: if your win7 is in C drive, install XP in D drive. hope you can do.
Aug 29, 2011 | Computers & Internet
I am unable to install windows XP. is it possible to install windows XP along with the Windows 7 that is already installed........ suggest me asap
If you want to have both windows 7 and windows xp installed on your computer, it is advisable that you first install windows xp. You should allways install the oldest windows version first. To install windows XP on your computer you need the installation cd. Boot your computer with the Windows XP installation cd, maybe you have to enter bios to set cd to boot first. Let me now if you need more information.
Jun 09, 2011 | HP PROMO ELITE 7100 MT WINDOWS 7...
I can not install windows live messenger and it appeals this error: msi check 0x080280002
To resolve this issue, please go to the link below and download the Windows installer 3.1.
Microsoft Windows Installer
After downloading the Microsoft Windows Installer, run the application to install. Once you have installed the Windows Installer, reboot your computer.
After rebooting your computer, attempt to install windows live messenger.
May 21, 2011 | Computers & Internet
Can i install windows-xp on my laptop which is currently working on windows-7 and use both of them.
Yes you can install windows xp in windows 7.
Windows XP Mode is a virtual PC image of Windows XP Service Pack 3 that could be run on Windows 7 Professional, Enterprise or Ultimate versions. Applications installed into Windows XP Mode could be run in Desktop Mode or Seamless Mode. In Seamless Mode, applications appear to run natively within Windows 7, but they are actually running inside the Windows XP virtual machine. Windows XP Mode might also provide additional integration that traditional Virtual PC images might not be giving. Applications installed on the Windows XP image could be exposed to the Windows 7 Start menu. Applications run in seamless mode is having automatic access to the Windows 7 known folders like Documents, Pictures, Desktop, Music, etc. Also the Cut-and-paste is enabled between native Windows 7 applications and those running in Windows XP Mode. Applications running in Windows XP Mode might also access your Windows 7 network connection and USB devices.
Nov 30, 2010 | Computers & Internet
Why will printmaster platinum 2.0 not uninstall
Try using the Windows Installermag-glass_10x10.gif CleanUp Utility. As long as you installed the application using the Windows Installer, this utility will remove all the folders, files, registry keys, and entries from your system and allow you to start over with a clean slate.
Download the Windows Installer CleanUp Utility
Locate and run msicuu2.exe to install the Windows Installer CleanUp Utility.
Locate and launch the Windows Installer CleanUp Utility on the Start menu.
From the Windows Installer CleanUp Utility window, locate the application in the list and click the Remove button.
Once the application has been removed, click the Exit button to close the utility.
You may now reinstall the application or at least have piece of mind that it is gone
This version of the Windows Installer CleanUp Utility works correctly in all 32-bit versions of Microsoft Windows. The 32-bit versions of Microsoft Windows are: :
Microsoft Windows Server 2003
Microsoft Windows XP
Microsoft Windows Millennium Edition
Microsoft Windows 2000
Microsoft Windows NT 4.0 with Service Pack 3 or later
Microsoft Windows 98
Microsoft Windows 95
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 17, 2010 | Broderbund PrintMaster Platinum 16
My window xp2 is not installing window installer 3.1 help me
Windows Installer 3.1 Redistributable supports Windows 2000 with Service Pack 3 or later, Windows XP, Windows XP Service Pack 1, Windows XP Service Pack 2 and Windows Server 2003. Windows Server 2003 Service Pack 1 contains Windows Installer 3.1 and therefore can't be installed or upgraded by this redistributable.
Read the above, Windows Installer 3.1 already in in SP2. Why do you need to install it?
Jul 14, 2010 | Microsoft Windows XP Professional
Windows Installer - Preparing To Install message keeps popping up
Try using the 'Windows Installer CleanUp Utility'. This utility helps resolve installation problems for programs that use Microsoft Windows Installer. If you use this utility, you may have to reinstall other programs. Caution is advised.
Use the following link: http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
You must be logged on to Windows with a user account that is a computer administrator to run Windows Installer CleanUp Utility.
When you use Windows Installer CleanUp Utility, you can perform the following functions:
  • Select one or more programs that were installed by Windows Installer from the Windows Installer CleanUp dialog box.
    To do this, select the programs that you want in the Installed Products list in the Windows Installer CleanUp dialog box. After you make this selection, the utility removes only Windows Installer configuration information that is related to those programs.
  • Remove all Windows Installer information associated with the selected programs. This includes the entries for the programs in the Add Or Remove Programs item in Control Panel. Be aware that only the Installer information for that particular program is removed, not the files.
If you use this utility to remove Windows Installer configuration information for your program and you plan to reinstall the program, you should reinstall the program in the same folder where you originally installed it. This prevents duplication of files on your hard disk or disks.
Apr 08, 2009 | Computers & Internet
Windows Installer prob
Do you experience this kind of problem whenever you attemp to install an application in windows box (2k, xp)?
"The Windows Installer service could not be accessed. This can occur if you are running Windows in safe mode, or if the Windows Installer is not correctly installed. Contact your support personnel for assistance."
The ms website knowledge article 324516 gives 2 methods as a way of fixing this problem, but you might be very lucky if any of the 2 fixes the problem, alot of guys end up formating their systems and doing fresh windows installations or try wired ways of fixing it.
Well, the solution is very easy:
1. right click your root windows installation drive i.e drive where you installed windows 2. click properties at the bottom 3. select security tab 4. click Add and scroll down to SYSTEM account click add and click OK. 5. allow Full control permission and click Apply and then Ok.
This should solve your problem with windows installer.
Oct 19, 2008 | Computers & Internet
GE EasyCam Webcam Logo
55 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
