Question about Dryers
Kenmore 110.62722100 Dryer has power to it, but it won't heat.  Is there a thermostat that can be replaced and if so, where is it?
  • lulaboy May 12, 2008
    exactly where it was... replaced both the fuse and thermostat. Works fine now.
    Thanks
  • Anonymous Jan 07, 2009
    The dryer runs but it does not blow out hot air?
  • 770 Answers
Remove the back unplug and look on the heating element right side there is a thermal fuse on the top and the heating element on the bottom with a high limit thermostat
Posted on May 10, 2008
  • Gary Davd
    Gary Davd May 12, 2008
    Glad to Help Thanks for the rate
Why won't my kenmore dryer 970-c85092-00 heat?
check the heating element to see if the coils are still intact (not burnt or brake). if it is fine,then check the T-STAT and the T-CUTOFF switch. one of those is your problem. if it is the T-STAT or T-CUTOFF, replace them both, they are inexpensive and easy to replace. here is a link to a video that explains this fix thoroughly. i think you will find it helpful.
Whirlpool Kenmore Dryer Repair Won Heat Test Fuse Thermostat 279816 or...
Jul 23, 2014 | Kenmore Dryers
Kenmore 70 series dryer won't heat
Post the model number for clarity. These tests should only be attempted by competent service personnel. Do you actually have 220 power? Are both legs of circuit hot...at 120v? While dryer is unplugged from power, check the heating coil for continuity. Also check continuity to ground from each end of heater (should not have continuity to ground at both ends). Also there should be power to the heating element when activated.
Mar 14, 2012 | Kenmore Dryers
Electric dryer won,t heat/replaced heating element last year,dryer worksbut won't hea
Hi galepezz...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Jul 25, 2011 | Kenmore 62602 Electric Dryer
Hi galepezz...
Check your Wiring
Jul 25, 2011 | Kenmore Dryers
Kenmore Gas Dryer 11072212101 won't heat. we
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
I have an older Kenmore gas dryer model # 97260100 it heats up for 15 minutes then goes cold, drum continues to run can u give me any insight as to what needs to be replaced
The problem is either of the cycling thermostat, high-limit thermostat or the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify any of these condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
Nov 08, 2010 | Kenmore 72872 Gas Dryer
Have a kenmore model # 110.72822101, where's the thermostat located, my dryer gets hot then cold
The cycling thermostat or the high-limit thermostat may not be the problem but rather the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify this condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Nov 08, 2010 | Kenmore 72822Gas Dryer
Kenmore series 70 dryer will not heat up replaced heating element thermostats check ok with ohm meter
If heating element was replaced and still no heat, Then what I would do is test the voltage current in the wiring and see if there is actually power to the element.
All parts to make dryer heat are:
heating element
thermal fuse
thermostat
timer
any one of these units can be faulty
Oct 10, 2009 | Kenmore Dryers
Dryers Logo
215 people viewed this question
Top Dryers Experts
