When i try to start telstra turbo connection the window pops up saying access violation ad address 0052d602 also a application error exception EOLeEXEPTION in module DLL_NETCARD_R.DLL at 000305c6. how can i fix this?
  • 12,061 Answers
Make sure it has NOT been installed with "Run this program in Compatability Mode for Windows" Check, the Shortcut, and the EXE too, sometimes this happens and it will not work.
Posted on Aug 26, 2010
The application failed to initialize properly (0xc0000005). click on ok to terminate the application
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
You can read more about DEP at:
http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Mar 03, 2011 | Computers & Internet
I bought an USB Celcom Broadband (HSUPA USB Stick (Model: ZTE MF190) a few days ago. I installed to my Ftec laptop (OS : Windows XP Pro SP3), but can't use. There are messages appears : (1) Exception...
hi sir,
i got a problem regarding the celcom broadband. the problem was happen since yesterday. i left my notebook for along time (may be about 20 hours) where i am not to turn off the celcom broadband. when i come back and see to my laptop, it's already shutdown. when i turn on the laptop.. the error problem pop up at my laptop screen. the error shows :
access violation 004A1170 in module UImain.exe. Read of address 0000051c'
please help me to solve the problem. i cannot access the broadband as previously. Thanks :(
Oct 08, 2010 | Microsoft Windows XP Professional With...
Error running th game "Casino Inc." in Windows XP SP2
What Causes Windows Error 0xC0000005
A quick scan of the online technical forums and blogs reveal folks asking for help with this windows error. Your question may be the same as this typical request:
I'm running Windows XP and when I click to start one of my software programs I get this error:
The error 0xC0000005 is generated by an ******* "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
/NOEXECUTE
Oct 30, 2017 | Konami Casino Inc. for Windows
Memory access violation C0000005
The exception number is an memory address space and the access violation means an application tried to access a memory space that belongs to something else -either a protected area of memory or the memory of another application. Try using Task Manager (ctrl & ALt & dlt) to find out what apps are running each time this happens to try and narrow down which is causing the error. It is usually a sign of bad code or a corrupted application. When you find out what application is causing the problem, try re-installing it
Mar 11, 2010 | Computers & Internet
Access violation at address 0052D602 in module telstra turbo connection manager.exe read of address 000002EC. Tks mal.
to solve this problem you should simply uninstall and re-install the Telstra software.
The software has some kind of misconfiguration and need to be recovered to the original state...
Jul 17, 2009 | Microsoft Windows XP Professional With...
Telstra Turbo connection access violation
try re-installing the net connection client.sud fix the problem
Jun 22, 2009 | Computers & Internet
Sorry If this doesnt help your problem but here is some info that might help
Consent.exe is part of Windows Vista - it's the User Access Control (UAC) executable.
There is a known malware version of this executable. Do a search on your hard drive (within Windows Vista, obviously) for all consent.exe files - make sure you include hidden and system files in the search criteria.
Once the search has completed, right-click on each file and check the file properties.
There is a MalWare version of Consent.exe
Right Click ALL of the ones you find and look for
Microsoft details in Properties
  • File Names Used: 3
  • Paths Used: 8
  • Common File Name: CONSENT.EXE
  • Common Path: ?:\windows.old\windows\winsxs\x86_microsoft-windows-lua_31bf3856ad364e35_6.0.5728.16387_none_ef1113b929fe5371\
  • Vendor Information: Microsoft Corporation
  • Product Information: Consent UI for administrative applications
  • Version Information: 6.0.5728.16387
  • CONSENT.EXE may use 3 or more path and file names, these are the most common:
  • 1 :%windir%\winsxs\backup\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • 2 :?:\windows.old\windows\winsxs\backup\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • 3 :?:\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • If you find a consent.exe anywhere else in the search results, I'd delete that file. Run a thorough anti-virus scan of the harddrive. I'd also download spybot and run it as well as downloading Ad-Aware from Lavasoft and using it to scan as well.
    Spybot and Ad-Aware can find different spyware/malware, which is why I recommend running both products.
    Once you've done all that, reboot the system. That should fix the problem.
    Jun 22, 2009 | Microsoft Windows XP Professional With...
    Have installed program and used it a couple of times - now get an
    Consider updateing the software or look through the FAQ on the product website.
    http://janome.com/index.cfm/Search
    Dec 17, 2008 | Janome Memory Craft 10000
    Computers & Internet Logo
    256 people viewed this question
    David Payne
    David Payne
