Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
The remote control that came with my Philips Flat Screen TV, Model 42PFL3603D/F7, no longer works.
  • Philips Master
  • 17,130 Answers
The best that can be done by you:
1. check the battery , replace if bad, check the battery terminal too, if bad clean.
2. Remove the covers, use a good soldering iron to solder the crystal and the processor in the board, use a thin needle to clean the pins after soldering to ensure that there is no bridging in the circuit.
3.use a dry wipe to clean the surface of the board. check if the IR Leds are working or out of circit, if so replace.
4. The transistors switching the IR should be checked.
5. If carbon pads are bad replace with spare dots available or use a carbon pen to line.
use a multimeter to check if the IR works ,if not the IC can be faulty
If none of the top works youmight have to cchange the IC .
Hope the advice helps.
Posted on Aug 26, 2010
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
How do i replace part number 932224306671 on a philips 42pfl3603d/f7
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | Philips Televison & Video
I have a Philips LCD TV. The remote seems to have stopped working. The TV has power going to it, but I cannot control the volume or select the input with the remote. The controls on the side of the TV...
Take a camera phone and point the remote at the camera, then press a button that you know is working the Tv - you will see a white flash from the remote LED when the button is pressed. If you press a button on the remote that does not work the Tv and you get a white flash from the remote LED when looking at the remote - as if you are going to take a photo of it - then the remote is good and the Tv is faulty. Visa versa, if you don't get a white flash then the remote is faulty.
If the remote is no longer available, then pop it open with a flat screwdriver and wash the remote with a mild mixture of dish washing soap and water. Then let it dry out in the sun until completely dry and then reassemble to try again. I have repaired remote controls in this way for people :)
Jul 31, 2014 | Philips 42PFL3603D/F7 42-Inch 1920 x 1080p...
Blue screen on Philips 42pfl3603d/f7
same result with all inputs? check all your input cables & connections
Nov 29, 2013 | Philips 42PFL3603D/27 42 in. LCD TV
MY PHILIPS MODEL 42PFL3603D/F7 TURNS ON WHEN YOU PLUG THE POWER IN AND THE BUTTONS DO NOT WORK
If the remote works for the set, both it and the buttons on the set go to the same place in these sets.
The Keyboard with the manual buttons may have a lockout feature--it can be locked to prevent children etc from tampering with the controls.
If no function from remote, that could be same issue or another==key board has priority over the remote control.
if all else fails carefully read the owner manual.
May 24, 2012 | Philips 42PFL3603D 42 in. LCD TV
My remote has stopped working. We have replaced the batteries with no luck because of this we cannot switch between sources My TV is a Philips 42" Model # 42PFL3603D/F7 Serial # VA180905005250
Hi:
The IR remote sensor in side of the television need replacing, this is the sensor that receives the commands from the remote and relays them to the microprocessor of the TV. Have the remote sensor replaced.
Mar 10, 2011 | Philips Televison & Video
Model 42pfl3603d/f7 tv stopped receiving signal from remote.. remote IS working.. side controls on tv work it just does not process the signal from the remote.. unplugging does not help.. any ideas?
If you find the remote sensor eye located on the front of the TV, you are there!!! There is a small sensor board and a TV tech will have to replace this for you. There is usually a capacitor, resistor or diode that will need replaced. I replaced the remote sensor board. Thanks for asking and show a few hands of support.
Jan 11, 2011 | Philips Televison & Video
Need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
What is the remote control code for philips 42pfl3603d lcd tv
Hi - I had the same question and found it here:
www.universalremote.com/resources/pdfs/UR2-CBL-CV04.pdf
Some TV brands have multiple codes associated to it. You must try each one individually until one of them does the job.
This worked for me beautifully on a brand spanking new Philips 42'' LCD.
Jan 02, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
124 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
