Question about Electronics - Others
OUR INVERTER IS USED ON A SANJO LETTERPRESS 8 COLOURS WHEN RUNNING THE UV LAMP IS NOT OPERATING NORMAL AT 80 OR AT 160 SO WHAT WE HAVE TO DO.
  • 905 Answers
Hi Michael,
I suspect that your inverter is a "Modified Sine Wave" or MSW type of inverter, and that while the majority of your press tolerates it, the ballast for the UV light doesn't like it.
What kind (make / model) of inverter are you using right now? I may be able to make suggestions on some alternatives, or perhaps a work-around.
Other than the press, what other loads are you supplying off the inverter, and what kind of battery bank do you have supplying the inverter? How is it wired (clamp or screw terminals, wire guage, etc), total AmpHour Capacity, System Voltage, and your desired run time. Also, how are you charging the batteries?
Posted on Aug 27, 2010
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
Leaking coolant dont know were is leaking from and is over heating
Coolant have colour just for this same thing so that you can see where it is leaking. I use green colour coolant which is most common and when I need to find a very minor leak (major ones are visible as green crystalline deposits) normally I use UV light. Under UV light the coolant shows florescence.
Other things to check in such cases are:
Radiator cap and Coolant valve which often get choked and do not open resulting in over heating of engine.
Feb 23, 2013 | 1999 Volvo S80
The UV-visible spectrophotometer(Cary 100 Bio, Varian company) in our lab is now showing faulty error while starting the instruments. It says Error Code: 9:9330SEQ:E9330, chopper not upto speed. Where to...
May be that your deuterium lamp for UV or possibly tungsten lamp is out or misaligned. Ran into something similar several years ago. The UV lamp initially ignited but shut down a short time later ( less than a minute) since there was not enough intensity being detected. The error message was similar.
Sep 30, 2010 | Kitchen Ranges
Does LCD monitor emit UV light?
The monitor use Fluorescent lamps (CCFL) to light up the screen, same kind as used for the home fluorescent lamps, no different, they are just smaller in size and lower wattages. Do you use fluorescent lamps in your house to be Green, if there are conflicting info then they would have banned fluorescent lamps a long time ago and will not be banning regular light bulbs in the future.
May 22, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
Fresh Air Display on and NO POWER
possibly a bad control finger control board. had a problem just like that and that repaired it.
Mar 27, 2010 | Ecoquest Fresh Air Living Air Purifier
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Computers & Internet
Sony vaio PCG-GRT30P Screen Problem
You could have a defective screen, either a faulty inverter or a CCFL lamp - follow this to determine the fault.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 15, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Pure ion uv light does not turn on
Where can I get a replacement ultraviolet germicidal lamp? I have been to Brookstone store and on line without help. My unit is a Pure Ion.
Thank you.
Dec 25, 2007 | Brookstone Pure-Ion UV Air Purifier
Ecoquest air purifier uv lamp replacement
If you haven't done so, try replacing the lamp starter.
Sep 29, 2007 | Ecoquest Fresh Air Air Purifier
Electronics - Others Logo
53 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
