Question about Kitchen Ranges
I have a model KML-450-MAH I have 120 volts to the control board but I get no led lights light up. If I push the start contactor in I get the compressor to kick in but no fan. What could be the problem? e-mail me at arlin.griffith@fpl.com Thanks
  • arlin_griffi Aug 27, 2010
    Sorry I forgot to put in my question that this is a Hoshizaki Ice machine.
  • Kitchen Ranges Master
  • 3,083 Answers
It sounds like the control board is bad, and that the contactor isn't getting voltage to it. I couldn't find a diagram of this unit on the net, but I did notice that they have a 3 year parts and labor warranty on the whole machine, in case you're still in the warranty period. This web page has a tech manual and service bulletin, which may be of help to you:
http://hvac-talk.com/vbb/showthread.php?p=1803821
Also, this page has user manuals:
http://www.retrevo.com/support/Hoshizaki-KML-450MAH-manual/id/23143ci067/t/2/
Wish I had more specific information, but hope this helps.
Posted on Aug 27, 2010
  • 11,896 Answers
If you have 120 volts to the control board, see how much power comes out of the control board to all components. Chances are you may have a faulty control board.
Posted on Aug 26, 2010
  • Nate Stansfield
    Nate Stansfield Aug 27, 2010
    I still think it's your control board. I would test the power coming out of the board and going to each component.
I need help troubleshooting my Heil home HVAC system. The system worked fine at the end of last year.
sounds like a bad contactor if you have 24 volts at coil and does not pull in. by manually holding contactor in you are doing what the contactor is suppose to do with 24 volts applied.
Jun 09, 2015 | Heating & Cooling
Battery state light stays on & discharges battery
something not right here with the question/request---""unplugging the 230 volt charger"????--I don't know of a 230 volt charger---unless this is in Europe---a 120 volt charger---in USA-- but I'll try this---a LED light does not use enough electricity to discharge a battery over night--- do you have another function on this unit such as a compressor or lights--something that maybe on???---another thought is that the battery has failed causing this malfunction----has this been wet/underwater---a malfunction with a diode in the electronics may cause the charger to try and charge the battery via ac and cook the battery as well as the circuit board---this is a real issue here---I'm not getting enough info to give an intelligent answer---i need to know if anything has happen what has happened before and up to this point when this issue started---I don't know what happens if when using these units if you connect to (jump start) battery with reverse polarity--if it bows a fuse or cooks the unit---sorry I can't be more helpful
Feb 14, 2015 | 450 Amp Battery Jump-Starter
The LED on my furnace blinks when starting up and the burner does not turn on. I have checked all of the voltages for the limit switches and the roll out switches and the blower on switch and all wor
The first thing to do is follow the sequence of operation. In order for the furnace to ignite the pressure switch must close, once the switch closes the control board will send 120 volts to the igniter. If you have a 120 volts to the igniter, but does not ignite, this indicates a bad igniter. If no 120 volts, the pressure switch or control board are likely the issue.
Oct 19, 2014 | Heating & Cooling
How to connect my well pump to timer
T8845PV has 120 volt input.... but 24Volt output,
You can use 24 volt to control contactor that can be used to switch 120-240 volt pump
Wiring on following link:
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
Dec 02, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
I have an intertherm furnace. It was working fine on saturday night. tried to turn it on sunday night it won't do anything. The led status light is off. Checked breakers, all good. tested the power...
Hello, test for 24 volts between r and c terminals and for 120 volts at L1 and neutal on the control board, if ther is voltage to the board then the control board is faulty and must be replaced.
Sep 06, 2011 | Intertherm P3RA-048K Air Conditioner
I have a Bowflex TC1000 that will not start. The console powers up, the red light on the power switch lights up and the green led and red led on the controler board are lit. A/C voltage to board is 120...
Check to make sure the yellow safety key is securely inserted into the console. If not, the control board will not send power to the motor. If this does not resolve the issue, check connections and continuity of wiring from console to control board.
Apr 20, 2011 | Bowflex TC1000 Treadclimber
I have hoshizaki kml 450 mah and i need water pump for it can you give me the part number . old onr is burnt out
I can get that pump. Look us up on the repair directory under refrigerators zip code 60060
Northeast Cooling LLC :)
Oct 01, 2009 | Hoshizaki KML-451M Low-Profile Crescent...
42FD9954 philips plasma TV flashing LED it wont come on
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Nov 08, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
