Question about RCA HD52W56 52" Rear Projection HDTV
Power problem Will come on and off at will. Unpluge from the wall for a couple minutes and will stay on for days. Turn it off and let sit overnight.....will not turn on, have to unplug from the wall and start all over again. Had a TV guru here and worked fine for a day. He replaced the flyback
  • Anonymous May 30, 2008
    comes on for a while then tures off for 10 sec. then comes back on
    Genius:
  • 1,030 Answers
Hum sounds familiar... you eather have a bad connection or your main processor has become corrupted...generally a signal board replacment may be nessarry... something on a tech with a computer interface can do. you have to download data off of old board to put on new board
Posted on May 12, 2008
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Wii console not working correctly
When you connect to the internet wirelessly and Wii Connect24 your Wii will stay connected and recieve messages, updates, etc. That is why the disk area stays blue and the amber light stays on. Sometimes this will create a power failure. Just unplug your Wii from the wall and let it rest for a few minutes and plug it back in. The problem should be solved.
Feb 22, 2010 | Nintendo Wii Console
Philips 50pf3691d/37 won't turn on!!!
If you don't have any green lights anymore on the power supply PCB, replace it (part number LJ44-00118A, can be found on-line for approx $180).
Jun 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
SAMSUNG DLP617W SCREEN GOES BLACK SOUND IS ON CAN"T USE REMOTE
u need the main digital board for this model cost about $250 - $350
Apr 05, 2008 | Samsung DLP HL-P5663W 56" TV
Main Menu
power supply regulator and horizontal output transistor.
Jan 17, 2008 | JVC AV-27230 27" TV
SET TRIES TO TURN, BUT DOESN'T
The RCA P52920BL uses the PTK195 series chassis. The most common reason for the set not turning on is a shorted flyback transformer. To check this, measure the B+ when the set is plugged in - it should be around 145 volts. When you turn the set on, see if the B+ drops down at all. If the flyback is shorted, the set will try to start but the flyback draws too much current. The microprocessor senses this and immediately shuts the set back off. To confirm, unsolder the jumper wire bringing B+ to the flyback and put a 100 Watt bulb in its place. Turn the set on and if the flyback is shorted, the set will now stay on but the bulb will glow as bright as if it was plugged into the wall. If this is the case, replace the flyback. Let me know what you find and we will take it from there.
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
RCA HD52W56 52" Rear Projection HDTV Logo
24 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
