Constant buzzing noise when using dvd player, playstation etc.
  • rumble1128 Aug 29, 2010
    Hope this is 4 witserv. Thanks for advise, just thought it was TV, but cant be as only happens when using other equipment, the buzzing quite loud, will have to get someone to check cables etc. Does this mean all cables faulty, ie, the dvd cables and play sation cables. Cant remember how or when it started unfortunately.(pretty useless).
    Novelist:
  • 144 Answers
If this "buzzing" sounds like a low frequency hum, then it is probably a loose or bad cable from the equipment. I am assuming you have this connected to an AV receiver or the tv. If the cables are not securely connected or is a damaged cable it causes the ground to be suceptible to "noise". That is what I would check first. Let me know if that fixes the problem, or what you did right before you noticed this issue.
Posted on Aug 26, 2010
Testimonial: "New to this, thought had already done this. Many thanks for advice, going to get someone to check cables, ( I'll probably make matters worse ). "
  • William Robinson
    William Robinson Aug 29, 2010
    Yes it is WIT Serv. You can also try this. At the AV receiver where the cables are connected and you hear the buzzing, touch the connector at the connection. There should be a small area of metal exposed at this junction. You won;t get shocked. See if the humm or buzzing stops or changes. This would be another indication of either a bad cable of a ground loop problem with the equipment. Let me know
Buzzing noise
If its doing it when turned off its in the standby power supply inside the unit which runs 7/24 if the unit is plugged to power.
Dec 06, 2012 | Sony DVP-SR200P DVD Player
Sony dvd player makes noise when turn it off
It is in the standby portion of the power supply which runs 7/24 if the unit is plugged into power.
Dec 06, 2012 | Sony Televison & Video
I just bought a Singstar bundle but the mics provide a constant buzzing noise when activated. I've tried different usb hubs and blowing on the ports but didnt work. It is only when the mic's are activated...
We've had the issue since PS3 purchase. I read on another forum today about having plugged the PS3 in the same power extension block as the TV causing the issue. Though this was not the cause of our buzzing on the PS3, it lead me to the fiind the cause of my buzzing noise problem . The issue is caused by use of Power over mains ethernet adapters, in my case these are used to connect my BT Vision unit to the internet. As soon as the unit makes a data connection to it's master unit, the humming starts! We are just going to have to power the nearest adapter off when we wish to make use of the MICs on the PS3!
Jul 29, 2010 | Sony Singstar - PS3
Buzzing noise from TV when playing DVD/Photos
Usually this noise is the result of a bad cable. Unplug to see if noise goes away. If so, try different cables.Has solved that problem for me several times over the years.
Dec 19, 2017 | Sony BDP-BX2 Blu-Ray Player
Buzzing sound when playing dvds
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your DVD player needs to be repaired. There is a part that has developed a defect and needs to be replaced. If the unit is no longer in warranty, it will be cheaper for you to replace the player rather than paying to have it repaired.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 04, 2009 | Philips Televison & Video
Loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Feb 07, 2009 | Philips DVP5140 DVD Player
Buzzing on DVD recorder when recording
The buzzing sound were feed back from power supply regulator if you can replace all of electrolytics capacitor in power supply block you will fix this problem or replace complet PCB
I need the correct model of your JVC DVD recorder
Dec 07, 2008 | Televison & Video
Loud buzzing noise
Out put Capacitor breaking down - needs a serive replacement if available.
Nov 13, 2006 | Sony DVP-NS55P DVD Player
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
