AN SC547 ERROR ON MY RICOH AFICIO MP C3000 MACHINE
  • 3 Answers
547 D Zero cross error § The zero cross signal is detected three times even though the heater relay is off when turning on the main power. § The zero cross signal is not detected for 2 seconds even though the heater relay is on after turning on the main power or closing the front door. § The detection error occurs twice or more in the 11 zero cross signal detections. This error is defined when the detected zero cross signal is less than 45. § Defective fusing lamp relay § Defective fusing lamp relay circuit § Unstable power supply 1. Check the power supply source. 2. Replace the PSU
Posted on Jul 28, 2011
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
Copier Gestetner Dsc530 (or Ricoh Aficio mp c3000) has error SC501 - tried to reset, but need to replace thermistor. Can't find a diagram on where it's located on the fusing unit. Anyone?
Error code SC501 is not a fuser problem. It is the top paper feed tray. Take all of the paper out of tray 1 and turn the machine all the way off. Turn it back on. Code should be cleared. If it returns with no paper in it the paper feed station has a broken part and can only be repaired by replacing it.
Nov 04, 2013 | Gestetner Office Equipment & Supplies
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
Ricoh afico 811 error sc689 and sc547
sc547 is a power supply error that can mean you have a faulty power supply. The service manual does not list an sc689, and it's not in the help desk support database either... are you sure that's the code that comes on the screen?
Oct 05, 2010 | Ricoh Aficio SP C811DN-DL Printer
Eror sc547
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, try to replace the Power Supply Unit.
Jul 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Part Number for RICOH Aficio 1022
The fuser part number for a aficio MPC 3000 isB2374053 USA
and B2374054 for EU
Jun 01, 2009 | Ricoh Aficio AP2000 Laser Printer
Part Number for RICOH Aficio MP C3000 Fuser Unit
Part number is: B237 4053 (North America)
B237 4054 (Europe)
I Expect this will be very expensive as it is not designed to be replaced as an entire assembly, but rather repaired as needed.
Feb 23, 2009 | Ricoh Aficio AP2000 Laser Printer
Ricoh mp c3000 display error code sc 502 on tray 2
make sure there is no paper at the back of the tray.also make sure the tray lift motor is working.the last thing to check is that there is nothig broking of the back of your paper tray..
May 02, 2008 | Ricoh Aficio 1018 Printer
360 people viewed this question
k24674
