I have a HP printer desk jet f4580 in my holiday apartment. When I leave printer for a few months cartridges appear to have dried out. Is there any way to fix or prevent happening rather than buying a replacement each time?
  • barry115 Aug 26, 2010
    I tried soaking cartridges in hot water as suggested and it worked perfectly
  • 10,515 Answers
If you would leave your printer for few months, the cartridges would dry. There is no way to escape from that.However, there are certain ways, you could get your dried cartridge. The different ways that are suggested are hit and trial options and there is never a guarantee. The ways are :-
1. The easiest way to prevent your ink from drying out is to print a test page every week. It seems that if you only use your printer once a month or so, the ink will be dried up and gone within a couple of months - way before the ink would have actually been used up by printing. However, printing a test sheet or some other page out of your inkjet printer every week should keep it fresh.
2. Another method that some people swear by, if you don't use your printer often, is to take the ink out after each use, and then store it in a bag with a moist cloth or paper towel. This will work to keep it fresh, but can be kind of a pain. I would say that this method would be best if you are going out of town for an extended period of time, or something like that.
3. Print Cartridge Kits. There are a number of print cartridge cleaning kits that would allow you to remove the dried ink clogging your ink printer cartridge so that you can use them again. Just like ink refill kits, make sure that you read and follow the instructions listed carefully.
4. Warm water baths. If your printer cartridge has not yet been used, but has already passed the expiration date, you can loosen up the ink by soaking the bottom portion for a minute or two in warm water. This can only be done on printer cartridges that have a copper portion on the bottom part of the printer cartridge.
Clear instructions
1. Run the printer's print-head cleaning utility. The location of this will vary depending on the printer, but it can usually be found on your computer under "Contol Panel" and "Printers," or in the case of printers with LED screens, on the printer's menu itself.
2 Remove the cartridge from the printer if the print-head cleaner doesn't cause ink to flow. Soak it in a bowl or sink filled with enough warm water to immerse the print head nozzles, long enough to see ink beginning to dissolve and flow into the water. Alternately, you can soak a cloth in warm water and use it to clean the nozzles until you see ink begin to flow.
3 Thoroughly dry the nozzles with a soft, lint-free cloth once the cleaning process is complete.
4 Replace the cartridge into the printer and run the printer's print-head cleaning utility.
5 Repeat the cleaning procedure if the cartridge still doesn't print. Reinstall and once again run the print-head cleaning utility.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 26, 2010
I have 2 HP printer/copier/scanners and neither will print black. Cleaned print heads but still the same. Ink in over 3/4 full!
Hello Donna,
Sounds simple enough. Take out all cartridges as if you was changing them. Remove all cartridges then remove the base the cartridge sit in. Run it under water leave to dry and place the cartridges back in.
Hope this helps, have a happy holidays.
Paul
Dec 20, 2014 | HP Office Equipment & Supplies
How do I reset the ink level on HP F4580 printer
It automatically reset them when you install them & close the lid.
Dec 14, 2014 | HP Open Box Deskjet F4580 All In One...
I need to instal hp f4580 office jet series
1 Go to hp.com 2 Click on Support and Drivers 3 Enter your product name or number, in this case just type in Officejet f4580 All-In-One 4 Hit go 5 Choose your operating system 6 Hit Next 7 Click on the link that says Driver - Product Installation Software 8 Save it to your desktop
If your printer no longer has a driver in the website. Try plugging it with a USB Cable and your Windows 7 should automatically install it.
Try Printing.
I hope this helped.
Feb 06, 2011 | HP OfficeJet J4580 All-In-One Laser...
Hp 5510 printer/copier/fax/scanner will not print docs. The paper goes through but nothing is on the paper. Tried to print test page, same result. I've checked the cartridge - not empty. Haven't used the...
It sounds like the jets on your cartridge is plugged. I have unplugged some cartridges by soaking the jets in alcohol. I pour some alcohol in a shallow dish and set the cartridge in it with printing jets down. Leave it for 5-10 minutes. If the jets start to unclog you will see the ink discolor the alcohol.
Be careful when wiping off the ink jets so you don't damage them. Use a soft cloth. Try the cartridge and see if it prints. If you need to soak it longer.
Jul 13, 2010 | HP Officejet 5510 All-In-One Thermal...
The flashing light on my h p 6940 desk jet printer wont turn off and the printer wont print
leave the machine on remove the cartridges close the door pull out the power cable leave it out for 10 seconds plug power cable in (note do not touch the power button) it should come on automatically when asked insert the cartridges one by one closing the door each time and follow on screen instructings
Nov 26, 2009 | HP Deskjet 6940 InkJet Printer
I have a hp desk jet 5440 i put i a new tricolor
Make sure that your buying a new Tricolor as the same and Geniune too.
Only solution to this is put it properly inside your printer.
At first sometimes New Cartridge are being initial & calibrate by your printer before it works.
Power Off first your printer and put the cartridge inside. If the problem still exist then put back again your old cartridge and identify what is the problem occur before you put a new cartridge on it.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP printers - remove and check cartridge. (Use it or lose it)
There is no solution for HP Printers being used very lightly - meaning "not for months" etc.
As a result, if you are stuck in this predicament - an HP inkjet, that you only need every few months - I instead suggest you set a calendar entry for once a week or more and run a test page.
The printer will "hopefully" not dry out by being periodically used - and the ink "wasted" will result in a LONGER cartridge life than if you had to throw out a cartridge.
There is also a time period, or sensing of the cartridge, that results in a wasteful cleaning cycle in which it pumps ink "down the drain", and I'd like to know how often to test print to avoid that.
My solution to my most recent problem was to "give up" and throw a new (black) cartridge on it and take the barely-used one out.
Jul 07, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP 6310 printer says HP 95 tricolor is empty.
Ray,
It sounds like you need to replace the cartridge with a new one. The electronics may have went out. We see this usually during the winter months when the static electricity in the air is high and we shock the cartridge. I would also NOT recommend cleaning the head/jets of the cartridge with alcohol. The electronics are fine to clean with alcohol both inside the printer and on the c artridge, but the head will dry out. We recommend taking a damp warm wet paper towel, placing it on a protected surface, and placing the head of the cartridge on the paper towel until you see some ink appear. Then put it back in your printer and let the printer clean off the bottom. If the printer is not cleaning off the bottom of the cartridge, the printer cartridge wiper on the carriage may be broken or stuck.
May 16, 2009 | HP Genuine HP 95 Tri-color Inkjet Print...
Hp 3745 desk jet problem
check whether its printing the test page properly directly from the printer not from the pc.for that print
1)just ON the printer
2)press the ON button
3)do not leave the ON button and lift the cover of the printer completely up and down 4times.
4)if you want to change the cartridges which front cover you will lift ,that you have to lift 4times up and down by pressing the ON button ,then leave the ON button the printer test page will come out of the printer .
5)keep the paper in the tray.
6)check that printout if its proper the printer is perfect
7)if the print is improper then the printer is having some problem.
8)also try changing the cartridges and see if its same or better prints comes out.
thanks.
Sep 18, 2008 | HP DeskJet 3745 Printer
Hp desk jet f 380
CHECK THE PREVIOUS PENDING PRINT
Mar 05, 2008 | HP DeskJet F380 All-In-One Printer
230 people viewed this question
k24674
jasbo
jasbo
