Replace the waste toner container (ir6020i) - Office Equipment & Supplies
3 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Waste Toner
 Remove the left rear side cover waste bottle is in the left rear corner of machine ..make sure to clean the neck of the bottle really good it uses sensor to know when full, if toner deposits stay on neck of bottle it cant see threw it so still thinks it is full, Toner is messy stuff, empty with care, while you are there locate the sensor that looks threw the neck and clean that too. You just saved 100bucks!!
Posted on Oct 31, 2007
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
I have an MFC Brother printer and I cant copy or print...it says waste toner full??? How do I fix this problem?
What model MFC Brother Printer do you have? The waste toner is left over toner from each print or copy that isn't used. It collects in a different spot in each printer. Usually the waste toner container is with the regular toner cartridge. The printer is able to detect when the waste toner is full by a light sensor in or near that container. Sometimes excess toner collects on the sensor itself and causes it to think the waste toner is full when it actually isn't. Try finding the waste toner container and empty it or replace it. clean the sensor that is on or near the container. it is likely a small black plastic piece that has 2 or 3 small wires coming from it. The model of printer will help to identify where the container is.
Jan 14, 2011 | Office Equipment & Supplies
I have just replaced my imaging unit - now it wants me to replace/install waste toner bin
When the life span of the waste toner container has expired or it's full, the smart panel program window appears on the computer, indicating the waste toner container needs to be replaced. Otherwise your machine stops printing.
To replace it follow these instructions:
-Turn the machine off, then wait a few minutes for the machine to cool.
-Using the handle, completely open the front cover.
-Pull the waste toner container out of the machine using its handle.
-Remove the container's cap from the container, and use it to close the waste toner container opening. Do not tilt or turn over the container.
-Take a new waste toner container out of its package.
-Insert the new container into position and then push it to make sure that it is firmly seated in place.
-Close the front cover firmly. If the front cover is not completely closed, the machine will not operate. -Please make sure all toner cartridges are installed properly. If any toner cartridge is installed improperly, the front cover do not close.
-Turn the machine on.
Dec 17, 2010 | Samsung CLX-3175FN Printer
The screen on my Phaser 6110 MFP says "Remove/Install Waste toner tank." I don't know what that is.
The life of the waste toner container unit is approximately 1,250 pages
for full color 5% image printing or 5,000 images for black printing. When
the life span of the waste toner container has expired, Replace/Install
Waste Toner Tank appears on the display of the control panel,
your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to
cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
4 Remove the container's cap from the container as shown below,
5 Take a new waste toner container out of its package.
Tip
Make sure that you lay the waste toner container on a flat
surface so that the toner does not spill.
Caution
Do not tilt or turn the tank over.
6 Insert the new container into position and then push it to make sure
7 Close the front cover firmly.
8 Turn the machine on.
Caution
operate.
Tip
After rebooting, your machine will automatically reset the
counter for the waste toner container
From the manual:
http://download.support.xerox.com/pub/docs/6110MFP/userdocs/any-os/en/B_Guide_EN.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 16, 2010 | Xerox Office Equipment & Supplies
Waste toner tank
Here are the steps to replace the waste toner tank:
1. Turn the machine off, and then wait a few minutes for the machine to cool.
2. Open the front cover.
3. Pull the waste toner container out of the machine using its handle.
Note: Make sure that you lay the waste toner container on a flat surface so that the toner does not spill.
4. Remove the container's cap from the container as shown below, and use it to close the waste toner container opening.
Caution: Do not tilt or turn over the container.
5. Take a new waste toner container out of its package.
6. Insert the new container into position and then push it to make sure that it is firmly seated in place.
7. Close the front cover firmly.
Caution: If the front cover is not completely closed, the machine will not operate.
8. Turn the machine on.
Note: After rebooting, your machine will automatically reset the counter for the waste toner container.
Dec 02, 2010 | Samsung CLX 3160fn All-In-One Printer
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
1 Turn the machine off, then wait a few minutes for the machine to cool.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Replace waste toner container message
Mar 04, 2009 | Samsung CLX 3160fn All-In-One Printer
The printer asks for waste toner to be replaced
your printer has waste toner container in it, and it's full. it's needs to be replaced.
if you have a new waste toner container and it's still saying needs replacement, the sensors on each side needs to be cleaned off.
Jun 14, 2008 | Brother Office Equipment & Supplies
51 people viewed this question
jasbo
jasbo
