Kenmore 110.44832 washing machine front loader manual
I need to replace my bellows/door seal/whatever it's called.... I see where you've offered to send out a pdf of the repair manual (or the whirlpool duet)... I need this desparately. my email addie is tazga@yahoo.com.
I've found a document that isn't very specific at http://www.applianceaid.com/image/Duet_boot_door.jpg
I'm hoping the repair manual will be more detailed.
Thanx!!!
jsrock516
  • 5911 Answers
SOURCE: Duet washer leaking
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
Posted on Sep 29, 2007
Master_Tech
  • 770 Answers
SOURCE: whirlpool duet washer
check your email
Posted on Apr 05, 2008
jsrock516
  • 5911 Answers
SOURCE: torn seal on Duet
If you are talking about the door boot, follow these instructions:
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you. Let me know if you need further assistance.
Posted on Apr 08, 2008
Master_Tech
  • 770 Answers
Check your Email
Posted on May 24, 2008
Lumpy816
  • 246 Answers
SOURCE: Replacing bellows on Whirlpool Duet HT model GHW9400PL0
I have not seen a tech sheet (or service manual) that details how to remove one of these. Basically, once you have your replacement boot (availible at local parts stoares or from the manufactures web site on line), You can follow these steps:
1 - Remove the front clamp. (a silver peice of wire with a spring at the botom) A small flat head screwdriver will let you pull it off.
2 - You will have a clamp on a hose that comes from the dispenser to the boot on some models that you will have to disconnect.
3 - There is a second clamp on the tub side itself. Remove it by using a short phillips head screw driver to unscrew it.
4 - remove the boot
5 - Reverse the procedure making sure to line the new boot up at the top. (there is a arrow that needs to be ligned up on the tub and the boot.
Taking the lower front panel off can give you a bit more room to work. You can take it off by removing the screws at it's bottom.
Posted on Jun 16, 2008
Water leaks from the front door. it leaks at the bottom of the door and puddles on the floor. Do I need a new gasket that seals the front door??
If you have a leaking FRONT LOADER, the following link explains how to access and inspect your washer for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of the cases with front loaders, the door bellow begins to leak. A routine inspection of the seal perimeter will tell you if there are any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Follow the tips in the links provided and make sure you inspect all the drain hoses, drain pump cover and tub seals as well.
If you have any questions, please post back and let me know. I hope you find this information helpful.
May 05, 2010 | Kenmore 46462 Front Load Washer
I have a duet front end loader the front seal leaks how do you replace it
The front door seal is referred to as the "bellow". They do wear out with age and can also become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or is no longer sealing correctly, the following link explains how to replace one:
repairclinic.com
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. Also DO NOT overload the washer. This can contribute to premature wear of the door bellow and cause rips and tears.
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Jan 31, 2010 | Kenmore HE2 Plus Front Load Washer
Boot rips
The door bellow on front loaders do wear out and require replacement. However, overloading the washer can contribute to premature wear or rips and tears due to items getting caught in the seal. If the bellow is ripped, it will require replacing or the washer will leak. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Replacing the rubber seal on the door
The following link explains how to replace the door bellow on a Kenmore Elite front loader:
NOTE: Review some of the testimonials as well. One user (DGBG) offers a quicker way of replacing the bellow if you're willing to give it a try.
Oct 06, 2009 | Kenmore Elite 45986 Front Load Washer
AWM 8143 front loader- rubber door needs to be replaced
Yes,it is called a bellow.If the tear is small enough and just on the front rim of the seal try gluing it with super glue,it will get you by till you can get it replaced.
Sep 07, 2009 | Whirlpool AWM8143 Front Load Washer
Door seal tangled in wash load.
It sounds like one of your retaining clamps may have come loose or something sharp may have snagged the door bellow and pulled it loose. You will need to inspect the bellow for any potential rips or tears and ensure the front and rear clamps that hold it in place are still intact and useable. You may be able to simply reattach the bellow and won't require parts. The following link explains how to replace a door bellow and lists the steps required for accessing and installing the clamps:
This isn't difficult, but it can be tedious. If you require replacement parts, you can order from any of the following web sites:
repairclinic.com
The part numbers for Kenmore Elite are as follows:
Door Bellow: 8181850
Front Bellow Clamp: 8182211
Rear Bellow Clamp: 8182210
All these sites offer great service if you determine you need parts. Shop around for the best prices.
Sep 03, 2009 | Kenmore Elite 45986 Front Load Washer
Door seal for washer smells stagnant?
hi,
i need to replace the computing pump to :
mile w754s.
wich website i can find?
thx
Nov 18, 2008 | Washing Machines
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
356 people viewed this question
Top Washing Machines Experts
