Question about Whirlpool Duet GHW9150P Front Load Washer
Where is the Analog Presure Switch located?...and Water level Switch?
  • 122 Answers
Take off the top panel, I think t20 torx, if it is a steam washer and has an f35 error code it is the pressure switch, replace switch, should be a right hand rear side of washer, follow small rubber pressure hose to switch
Posted on Aug 26, 2010
What's your problem?code F35 is coming up
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned. This problem could be caused by a failed analog pressure sensor, a problem with the air tube connection between the analog pressure sensor and the bottom of the washer tub or a failed central control unit.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
A loose wiring connection or a broken wire harness could be causing this problem. You can remove the top panel of the washer by taking out the screws at the very back of the top panel. Pull the panel back slightly and then lift it up and off of the washer. Check the wire harness connected to the analog pressure sensor. Also check the air tube connected to this component. If these connections are okay, check the analog pressure sensor connection on the central control unit. THE IMAGE BELOW (click the link for zoom) shows the location of the central control unit on a similar model of washer and also provides a wiring diagram. The analog pressure sensor harness plugs into the central control unit on the PR8 connector. Make sure that this connection is secure. Look for damage to the wire harness.
If this dont solve it, I suggest replace the analog pressure sensor (shown in THIS LINK). Additionally, keep in mind that if your device is less than a year old, then this component is under warranty and should be replaced by a dealer technician.
Oct 13, 2011 | Kenmore Elite 45986 Front Load Washer
F35 error need to replace analog switch
F35 error code means a problem with the ANALOG PRESSURE SENSOR switch operation
Could be a blockage in the air dome or pressure switch hose (Item 29). The pressure switch is located underneath the main top on the right hand side. (See image) The air dome is located on the back of the tub on the left hand side.
If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (Item # 20) Part # W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Part Number W10156252 (AP4323930) is used with the following appliance models: WFW9600TA00, WFW9600TB00, WFW9600TC00, WFW9600TU00, WFW9600TW00, WFW9600TZ00, and more.
Hope this helps.
Jul 15, 2011 | Washing Machines
How to install presure switch
Hi.
The pressure switch is located behind the control panel. Its unction is determining the level of water in the washer.The switch looks like a round shaped plastic switch connected to wires and to a long thin rubber hose. To replace the switch disconnect power. Undo the screws holding the control assembly. Remove control assembly cover. Disconnect wires from switch and undo the screw holding the switch. Pull out the rubber hose from the tub and perform operations in reverse order to install the new part.
The switch is part nr.4 in diagram below. Click on the picture to enlarge:
Jul 07, 2011 | Maytag MTW5700TQ Top Load Washer
We have a Kenmore 90 Series washer and the water level function has stopped working and the water does not shut off - it just keeping running - therefore the wash cycle does not begin b/c it just keeps...
The ppart you are looking for is called the water presure switch and it is located inside the control panel.It will have a small plastic hose going to it. Hope this helped.
Jun 03, 2011 | Kenmore Washing Machines
Kenmore waher he3k. i want to know the location of
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^$%
Feb 13, 2010 | Kenmore Elite 45986 Front Load Washer
Finding the pressure switch and the pressure sensor tube
Water level switch is in the control area right behind the water level knob. There should be a tube conected to it. Follow the tub to the bottom of the tub. If this tube is not connected it will just keep filling. If you find the tube disconnected you will need to reconect the tube and drain the water and try refilling. If this tube is conected the take the tube off of the water presure switch and blow air through it to make sure it is not cloged and reconect, drain water and retest. if this still does not solve your problem your presure switch is probably bad and you will need to change it. every time you test you must drain the water so the tube will get air presure. If the tube has a crack or hose it will need to be replaced.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool dishwasher low water presure upper level
Since you have low pressure
  • Check the float switch inside the tub, it should move freely up and down.
  • Check the harness to the motor
  • Check start capacitor on the left side of the wash motor
Jan 31, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Washer overfilling tub and not shutting off
did it start agaitating? if yes then its your water valve.[where the fill hoses attach to washer from house] if no then it has to do with water level switch.in whirlpool/kenmore washers its very common for the water presure tube to come off of the water level switch.up in the timer console area.other brands dont have that happen as much.some times a mouse has chewed in that presure tube .see what you can do with that.check back with us if needing more help. God bless ,tom
Jan 06, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal De
