Question about Motorola Mobility RAZR V3i Cellular Phone
Bluetooth won't power on
I just bought a v3i off ebay. I have been trying to get the bluetooth to power on so I can transfer files from my old phone, but every time I try it just says bluetooth power failed. Do I need to send the phone back for another?? Thanks! (I have gone to settings>connection>bluetooth link>setup>power:on)
When you power on bluetooth and do nothing within 60 seconds it does not work and then you will have to apply "find me"
Posted on May 06, 2008
I need to connect a bluetooth to my razr
Do you need to connect a bluetooth headset , or do you need to start bluetooth file transfers?
In either case, to activate blue tooth on the RAZR V3i go to settings>connections>bluetooth (May appear as "bluetooth link") > hands free> look for device. The Razr will scan for other bluetooth devices. If you need to send files over bluetooth, turn on the blue tooth antenna, and navigate to the files you wish to send. Press the menu button, and press "copy" and select the device you wish to send it to in the devices list. If there is no device, or the device you with to send it to is not in the list, press "look for devices".
Mar 28, 2011 | Motorola Mobility RAZR V3i Cellular Phone
My Samsung galaxy portal GT-15700 phone will not allow files to be transfered to mobile, or to even transfer files to my computer or to send this files via bluetooth.It always says 'not...
I have the same problem with the same phone.
I bought a Zeemote (bluetooth controller) which needs to have a .sis file installed on the phone, but the phone does not recognize the file type.
Please help.
As for mefonna's problem, I usually connect my phone to my laptop, go into 'My Computer' to access the phone and just transfer files (drag and drop) across directly to your phone from there.
There is also an app you could download called 'Bluetooth File Transfer' (which is free) to transfer files via bluetooth.
Jan 12, 2011 | Samsung Propel Pro SGH-i627 Cell Phone
How do i load music into my new i856 by boost
according to motorola, this phone has bluetooth and micro SD card slot.
if you have computer with bluetooth, then you can pair the computer and phone and simply send music files wirelessly via bluetooth.
if you dont have bluetooth, then you can buy a cheap usb bluetooth adapter from ebay and have a bluetooth enabled computer, then follow above step.
if you have SD card slot on your computer then you can get a SD card to micro SD card slot adapter from ebay or elsewhere, where you can simply put music on then card from pc and then transfer the card to the phone.
here is the phone manual.for safety read the whole manual.
p.55 for music and p.79 for bluetooth instructions.
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i856/US-EN/_Documents/Static_Files/i856_UG__%20Boost_NNTN7815A_.pdf
Nov 06, 2009 | Motorola Mobility i850 Cellular Phone
Can't bluetooth files from old phone or download ringtone
simply use a new phone or if u cant afford it use ur natural blutooth device (. ) ( . )
Sep 25, 2009 | HTC Hero Smartphone
Transferring Music From PC to Cellphone
hi ,,,did you bought a bluetooth or usb cable..please be clear
Jan 13, 2009 | LG RUMOR Cellular Phone
Motorola VGA Zoom 4X can't transfer photos to computer
Have you used Motorola Phone Tools? Try using that. It will cost $20 but well worth it.
Dec 19, 2008 | Motorola Mobility RAZR V3
Memory card in Motorola v3i cell phone
How are you copying these Files, USB Cable to the phone, or a card reader?
What operating system are you using?
I/O device problem, disconnect from usb, wait a minute then plug it back in, it might not have installed correctly. (if problems persist with this you might need to acess Device Manager)
Does this phone have Itunes in it? are you attempting to transfer files using I tunes.
I found putting the card into a card reader attached to my PC works best, using MP3s.
Below is assuming you are using a card reader and a PC.
It works like any flash drive.
I would format the memory card
(open your My computer, where you should see all the drives in your PC, you should see the flash drive/ card there, right click on it and a window will pop up, click on quick format )
what file type are you attempting to transfer.
I open the flash drive, then I open my music folder (transfering only MP3s), I drag my files from one to the other.
On mine I currently have jpg files and MP3 files and I can acess this from my phone. ( I have the same phone)
I also have some bluetooth heads phones which work pretty well to.
Oct 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Lstening to music with a bluetooth headset
The bluetooth headset is not compatible with mp3's. try converting it to a different file and listening to see if it works
Apr 12, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth failure
pleace select your bluetooth in your menu and you see bluetooth turn on for fuw minits or scoend set it for long time then start file copy
Jul 19, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
