Uses for DHCP, DNS, TCP/IP - Computers & Internet
  • 12,061 Answers
DHCP: Domain Host Computer Protozoic. Basically an Address serving device, a "Client" "Asks" the DHCP "Server" for an "Address" on the network it is communicating on. THe DHCP Server, then sends that particular "Client" the ADDRESS, which, the device then "Stores" and Can then be identified by and Identify with that address when required.
Basically it is a Name Giver, and Finder.
DNS: Is Domain Name Server, Similar to a DHCP server, but in this case the device Translate Words and letters into an address, so the the DHCP server and other numerical only devices, can Ask for and Receive from "Other " "Addresses", that were described initially as Word Address, EG: WWW.Address.com, translates to (just say), 123.456.678:90.
If a device cannot "Understand" the Alphanumeric Address is then "Asks: the DNS, server, to "Translate" it into a "Numerical" one, that it can understand.
Basically it is a Translator.
TCP/IP: Transmission Control Protocol, Over, the Internet Protocol. It is basically a encryption algorithm, applied to all/any signals, that is then, introduced to, and transmitted to, and received over, the Internet Protocol signal, (Internet Standards of Operation) The Signal the internet operates "On". It is the bench mark, the correct way of doing it, a set of Rules.
Basically a Encryption vehicle and set of rules & standards.
Posted on Aug 26, 2010
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Tip
CMD for Your Network
use this procedure cmd and make your Network Fix.
Berikut adalah perintah-perintah pada Command Prompt yang berhubungan dengan jaringan
komputer.
Untuk melakukan perintah-perintah tersebut Anda harus masuk ke Command Prompt ( Klik Start
->Run ->Ketik CMD )
1. ipconfig /all
Menampilkan informasi konfigurasi koneksi, misalnya Host Name, Primary DNS Type, Ethernet
Adapter LAN.
2. ipconfig /flushdns
Menghapus DNS Cache
3. ipconfig /release
“Menghapus” semua koneksi IP Address.
4. ipconfig /renew
Membuat IP Address baru untuk adapter tertentu.
5. ipconfig /displaydns
Menampilkan DNS Cache.
6. ipconfig /registerdns
Melakukan refresh DNS dan meregister kembali koneksi DNS.
7. ipconfig /showclassid
Menampilkan informasi DHCP Class.
8. ipconfig /setclassid
Mengubah DHCP Class ID
9. control netconnections
Menampilkan Network Connection.
10. nslookup
Mengetahui alamat ip address dari nama domain yang di tuliskan
11. netstat
Menampilkan informasi koneksi TCP/IP yang sedang aktif.
12. route
Menampilkan local route.
13. hostname
Menampilkan nama komputer.
14. ping
Contoh: ping www.finderonly.com
Melakukan test koneksi ke situs www.finderonly.com.
Semakin sedikit % loss-nya maka semakin baik koneksinya.
15. tracert
Menampilkan informasi IP Address route.
on Apr 27, 2010 | Computers & Internet
Got a netgear usb wireless adaptor, it won't assign an IP address for this computer. Where do I set the DHCP to assign an address automatically?
Open Control Panel - Network Connections then right click on the Wireless Network (USB wireless adapter) and then click on Properties. Then in "This connection uses the following items" scroll down to Internet Protocol (TCP/IP) then click on Properties and in the General tab select "Obtain an IP address automatically" also select "Obtain an DNS address automatically" Then click OK
Apr 07, 2011 | Computers & Internet
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Dec 19, 2010 | RCA Computers & Internet
Unable to establish connection between PC and router.
Check your PC NIC card is installed properly in device manager or connect your PC directly to MODEM and check if IP, DG and DNS would appear.
If that works, then you know its the router (Belkin). Try resetting it to factory defaults by pressing the RESET button.
Jul 26, 2010 | Belkin Wireless G Router
I had to assign my router a new IP address and that made the wireless computer loose its connection, how do i reassign the wireless computer to the new IP address?
That is easy. You have to change the Default Gateway. Make sure you are running DHCP in the Router as well. Otherwise you may have to change the IP Address of the Computer to suite the New IP Address and its Subnet.
  1. You have to go to "Network Connections" in the Control panel.
  2. Go to the Wireless Adapter Section and Choose the Local Connection.
  3. Right Click on Properties and the Double Click on Internet Protocol (TCP/IP).
  4. If you are using a "Static IP Address", Please change the IP Address of your Machine to suite the IP Address and Change the Default Gateway to the New Address (And then the DNS Server Address as well, if you are running DNS from your Router).
  5. If you are running DHCP (You will see that the boxes are Blank and "Obtain IP Address Automatically" and "Obtain DNS Address Automatically" selected) this cannot happen. Then you have to check your Router's DNS Settings for the Internal Network. Make Suitable Changes.
  6. If you have tried this only once and if you have the DHCP running try changing only the DNS in the TCP/IP settings. It may work. Or try to Release the IP and Renewing it.
  7. Use ipconfig /release and then ipconfig / renew on a Command Prompt.
  8. If you are running DNS and DHCP Locally, then you have to change their settings to Point to the Router.
Hope this will solve the issue. If it helped you so, please be kind enough to Rate the answer with a Testimonial.
Feel free to contact again if the problem Persists.
Thanks for contacting Fixya!
Jun 12, 2010 | Linksys Wireless-G WRT54G Router
I want to find out the dns code for my belkin56g
If the light is yellow then you are connected to your wireless network, but not connected to the internet, make sure that airport is configured ( configure IPv4) for DHCP under TCP/IP tab so you can get an IP address. Don't worry about DNS servers, they should be provided automatically once you have an IP address.
if the light is grey try Configure IPv4 just with DHCP, not with manual address, and click the renew DHCP Lease button
Oct 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Says I have an invalid IP address
Go to control panel select network right click icon go to tcp/ip properties and choose get ip address automatically DHCP
May 01, 2009 | Gateway GT4016 Desktop PC
Computer
You are going to go to the tcp/ip settings and enter a permanent ip address.
If you access the internet you could always use the ip address you are getting from dhcp, just go to start-run and type cmd then at the command prompt type ipconfig and copy the ip, subnet, gw and dns to the tcp/ip settings.
Thank you for choosing agadycom.
Nov 13, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
273 people viewed this question
David Payne
David Payne
