Question about Homelite Mighty Lite Lawn Trimmer
Need to know color code for 220VAC receptacle, so can wire up an output cord. Had no cord with the generator. Have LRE 5500 portable generator. Have new 4 prong plug.
  • 905 Answers
Hello Arthur,
For 220vac, you will have 2 blacks or Red and Black (line). The white is neutral, green / bare is your ground.
If you look closely at the plug, the contacts for the line will have either black screws, or be labeled as L1 and L2. Neutral will have a white or silver screw, may be labeled as N, and the ground will be green or silver, labeled as Ground, Gnd, E, or Earth.
Posted on Aug 27, 2010
Portable 5500 watt generator no ac output
maybe it needs new brushes. you've done everything else
Aug 25, 2017 | Electrical Supplies
I have a 5500Watt BSI550 generator that lost AC while in use. It's only putting out about 5VAC. I Tried several other capacitors and even without a cap it's still putting out about 5VAC right at the...
No electrical
output
1. Faulty receptacle. 1. Have Service Center
replace.
2. Circuit breaker kicked out. 2. Depress and reset.
3. Defective capacitor. 3. Have Service Center
replace capacitor.
4. Faulty power cord. 4. Repair or replace cord.
5. GFCI switch breaker kicked
out (if equipped)
5. Depress and reset
Apr 28, 2011 | Porter Cable 5,500 Watt Portable Generator...
Onan 4 ky generator quits when a/c is turned on? Has no other load on it.
Is your generator 4 kW or 4000 Model 5500.
If 5500 as on the picture over your question the reason may be short in the receptacles or low voltage/ rpm.
If 4 kW MicroQuiet, there the reasons may be too much, that you will nead a troubleshooting manual.
Jun 14, 2010 | Watts Onan Portable Generator - 4000 ,...
No power output from Briggs & Stratton ProMax 7500E generator
You may have exciting field broken. Look for a fuse or wire break.
Jun 04, 2010 | Briggs Stratton Portable Generator 305cc...
560 operating hours; no output: breaker good.
Is there voltage on generator terminals. If not you must recharge the field or check the Voltage Regulator output
Apr 20, 2010 | Watts Onan Portable Generator - 4000 ,...
I have a 3 prong to change to a 4 prong cord on my dryer
The following link explains how to correctly install a 220VAC appliance cord to your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral ad ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Let me know if you require further assistance. I hope this help you.
Feb 06, 2010 | Dryers
RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Aug 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Mar 02, 2009 | Watts Onan Portable Generator - 4000 ,...
GE dryer barely heating
If this is an ELECTRIC dryer, you're supposed to read 120VAC at both L1 and L2. With the cord UNPLUGGED, check the voltage across L1 and l2 at the wall receptacle. You should read a cumulative of 220-240VAC. If you're only getting 120VAC, the problem is at your receptacle, which would explain why the dryer is not heating. The heating circuits and timer require 220VAC, while the drive motor only requires 120VAC. If the power at the receptacle is good, leave the dryer unplugged and check the continuity of the power cord from the end of the plug at L2 to the terminal block at the back of the dryer. You should read a short or 0 ohms. If the continuity of the plug is good, the problem may be a loose connection at the terminal block or a broken wire. If the continuity is bad (open), then it looks like you may have a bad power cord. Please post back if you have questions. I hope this helps you.
Jan 03, 2009 | GE DVLR223 Dryers
Homelite Mighty Lite Lawn Trimmer  Logo
292 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
