Question about Cameras
Kodai C330 camera lens error 14 - Cameras
  • 12,061 Answers
Ok, this has reported to have worked, before, anyway it's well worth a try. So remove the batteries & card & hit the bottom of the camera Flat, and evenly, against a hard surface & press the shutter button, at the same time, repeat, if at first not successful.
I think, if it doesn't work, after say three or so applications of percussive maintenance, then i'd think, that may not the solution.
Posted on Aug 26, 2010
The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
May 28, 2009 | Kodak EasyShare C330 Digital Camera
Lens error 14 then camera turns off
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 08, 2009 | Kodak EasyShare C330 Digital Camera
MY LENS SAYS ERROR 14 WHEN I TURN IT ON IT JUST SHUTS OFF
Apr 18, 2009 | Kodak EasyShare C330 Digital Camera
Kodak C330 [lens error 14]
Hi Jesse, thanks for coming to FixYa.
The problem your having is that sand and/or dirt gets in the lens mechanism of the camera. When the little cog inside gets sand in it, it prevents it from moving. It is what causes 95 percent of all lens errors. The other 5 are when the retaining pins get misaligned and don't go back in the holes. Mis aligned pins happen alot of times when you drop it with the lens extended, so let's go with the easy one first.
Take an air compressor (or borrow a friends) and put the nozzle up to the space in between the lens and and the camera. Blow it out real good. It may take a couple of tries, but it should free it up.
Let me know if that helped, and feel free to rate my answer.
Rob
Mar 04, 2009 | Kodak EasyShare C330 Digital Camera
Kodak Easy Share C330 lens error 14 and lens error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 08, 2008 | Kodak EasyShare C743 Digital Camera
Camera error message
This suggests a stalled lens motor.
Check Kodak for repair costs
A new camera may be as cheap.
Dec 26, 2007 | Kodak EasyShare C330 Digital Camera
Lens won't come out,lens error 14,kodak c330
same thing happened on my camera. think it got dropped. lens only comes out part way. pull out with fingers and then lens works fine.
Nov 27, 2007 | Kodak EasyShare C330 Digital Camera
I bought two of these on clearance and gave one to my in-laws. She suspected that one of her kids may have dropped the camera or pushed in the lens. I don't remember which lens error number had shown up, but I dis-assembled the camera to find out what the deal was. If I remember correctly, there is a way to manually turn the gears to put he lens back out. I left the lens out and turned it on and it worked perfectly. Fair warning though. It is VERY IMPORTANT not to touch the contacts for the flash EVEN WITH THE BATTERIES OUT!!! God did it hurt like hell... unfortunately it is fairly easy to do and I must have accidentally done it about 4-5 times while messing with it..
Sep 05, 2007 | Kodak EasyShare C330 Digital Camera
I have this camera and I have had this exact error...and I'm sure it was caused from being in my purse and turning on and off all the time. All I did to fix it was push the lens a little bit while it was already retracted and it made a slight popping noise like it was going back onto a track and then it worked perfectly ever since then.
Aug 26, 2006 | Kodak EasyShare C330 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
