Question about Sport & Outdoor - Others
I have a Tunturi C6, elliptical, from time to time while I'm using it my resistance stops and I'm free pediling, this has happened a few times and its frustraiting additionaly it may not work agian for days weeks or months at a time after that, I think that it might be the controler, and not the console, what do you suggest or how to repair
  • ebmxiv Aug 26, 2010
    have a Tunturi C6, elliptical, from time to time while I'm using it my resistance stops and I'm free pediling,and I'm free peadling like a cartoon character (the power is still on) and the consol screen remains lit (however there are no changes to the progression lights) this has happened a few times and its frustraiting additionaly it may not work agian for days weeks or months at a time after that, I think that it might be the controler, and not the console, what do you suggest or how to repair
  • Sport & Outd... Master
  • 3,083 Answers
I couldn't find any other reports of this problem, but it will concern something in the electro-magnetic resistance circuit that is failing.
It could be the controller, the wiring to the electro-magnet, or the electro-magnet itself. The unit will have to be troubleshot to figure it out, thus partially disassembled, at any rate. You could start by measuring the voltage to the electro-magnet, and then go from there- that would be a good starting point. Here is Tunturi's support website, and they may have some handy information or help for you concerning your problem:
http://fitness-en.tunturi.com/service/service_form/
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 26, 2010
    Genius:
  • 1,478 Answers
Power issues with
Tunturi C6 fit into two categories: the power does not turn on or the power shuts off when using the Tunturi C6. If the power will not turn on, make sure that the Tunturi C6 is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the Tunturi C6 . Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the
Tunturi C6 will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the
Tunturi C6.
If the
Tunturi C6 shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Take care.
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Need a repair to crosstrainer
Sounds like the pulley (bearing) in the back is loose or broken
Apr 27, 2014 | Tunturi C80 Elliptical Cross Trainer
NordicTrack ASR 630 Elliptical Console isn't working
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
Nov 27, 2012 | Nordic Track Nordictrack Asr 630...
Tunturi E40 I'm free peddling , the speed stays at 0, the resistance stops, nevertheless the heartbeat is taken normally.
Dear Sir:
Please adjust the sensor speed , see the diagram below 2) Tigh the wires from the sensor speed 3) Run the sotware CALIBRATION very IMPORTANT! for easy diagnose and troubleshooting
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 16, 2012 | Exercise & Fitness
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Loud knocking noise with increased resistance
Sounds like you a bearing in flywheel is failing need to call Accell Fitness of North America @ Phone: 1-800-667-1020 they are the distributors of Tunturi equipment
May 03, 2010 | Exercise & Fitness
Tunturi elliptical cross trainer error e-2
Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to http://accellfitnessna.com or Email a.parker@accellfitness.com they will help you they Tunturi Distributor of North America
Apr 02, 2010 | Exercise & Fitness
Abrupt stop Tunturi J 660.
I am all set. I located a Tunturi service person in my area. We have an appointment set up. Thanks for following up. I. Hazelhoff
Jan 21, 2010 | Tunturi Exercise & Fitness
Sport & Outdoor - Others Logo
363 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
