Question about Kyocera FS-1118MFP Laser Printer
Kyocera mfp 1018 showing c6000,how do i clear it
5 Suggested Answers
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
SOURCE: my kyocera printer km;2035 is showing c6000
My kyocera printer km;2035 is showing c6000
Posted on Feb 14, 2011
the menu does not open. What should I do?
Posted on Mar 25, 2011
shawn38
  • 200 Answers
SOURCE: Service code for this printer came up C6000 what
This is a fixing unit error. If you have had a power outage or your power has flickered it maybe able to be reset with out parts. Go to www.gfbm.net and call thier number and they should be able to reset it over the phone at no charge.
Posted on Feb 19, 2010
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 ยท Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
How do I clear the memory on a ECosys FS-C2126 Copy/printer
it is under mode 21, you need to login first to maintenance mode by punching the numbers 1087 1087. then select the number 21 then hit start. you will be able to clear the memory .
Jun 10, 2015 | Copystar Kyocera FS-C2126 MFP Color...
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
My kyocera 1635 copy shows c6000 error i need a code to cancle it
u cannot clear it if it is c600... if is c6400, u can fix it by entering mtce mode: press 1,0,8,7,1,0,8,7 in sequence after switch ON; u get "U" ,, now enter 1, 6, 3... press enter/start; cle appears; press enter/start; u get the machine ready now. if c600 fuser lamp might be blown, needs replace; first try as above.
Apr 04, 2014 | Kyocera Copystar CS-1620 Black and White...
Kyocera 2050 errore code c6000 problam
Error C6000 is a fuser error.
Solution 1:
  • Turn it off
  • Wait 5 minutes
  • Turn it on and the code will be clear.
Solution 2:reset the fuser
  • First open top cover then turn on power.
  • press system menu/counter
  • arrow down to service
  • press and hold start, # then enter keys
  • arrow down to maintenance
  • press enter
  • arrow down to Sim 163
  • press enter
  • select execute
  • press enter
  • turn off power then back on
Solution 3:
  • You need to replace the fuser
Sep 25, 2013 | Kyocera Office Equipment & Supplies
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
Kyocera FS-1118MFP Laser Printer Logo
599 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
