Question about Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system
What is the difference between sa-bt200 and sc-bt200 ?
Beim Firmware Update stopt das System bei UPD5/5 - keine weitere Reaktion ???
the firmware update for sc-bt200 & sa-bt200 takes approx 10 mins. the box will display UPD5/5 - this process takes about 10-15 minutes, the box will switch off automatically. Leave for 30 seconds, and power on manually with your remote control - the screen will display - "firwmware update completed.".
Feb 05, 2011 | Panasonic SC-BT200 Home Theater Systems....
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
My panasonic sc-bt200 wont play the 3d version of a christmas carol so were can i get the firmware to update it
The SC-BT200 is not a 3D Blu-ray player. You cannot play 3D Blu-rays on it. To watch 3D Blu-rays you need a 3D Blu-ray player, a high-speed HDMI cable, a 3D TV and compatible 3D glasses.
Nov 05, 2010 | Panasonic SCBT200 Theater System
Just want to know difference between Panasonic SA BT200 and SC BT200..theater systems..
from what I can see, the number for the whole system is sc-bt200, while the main unit alone (the bluray player itself) is sa-bt200. The system comes with speakers which all have their own numbers too.
Oct 17, 2010 | Televison & Video
PANASONIC SC-BT200 UNLOCK REGION CODE
Google for "Panasonic SC-BT200 Region Free
Also see
"http://www.avforums.com/forums/blu-ray-players/885440-blu-ray-player-multi-region-hex-codes.html"
Some Blu-Ray players will need a hardware mod to be region free.
Feb 05, 2010 | Panasonic SC-BT200 Home Theater Systems....
Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system Logo
152 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
