Question about Sony Playstation 3 (PS3) Console
I AM TRYING TO RECONNECT MY PS3 ON MY LCD TV AFTER 2 WEEK BEEING DISCONNECTED AND IT DOESNT SEEM TO WORK THREW HDMI CABLE! IT SAYS THAT HDMI CABLE WAS DETECTED BUT WHEN I AM ON HDMI CHANNEL ON TV THERE IS JUST BLACK SCREEN! I EVEN TRIED THE DISPLAY SETTINGS ON PS3 TO WORK WITH HDMI BUT STILL THE SAME BLACK SCREEN !!!! PLEASE HELP !!!
    President:
  • 1,139 Answers
I think maybe the following steps might help you out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Posted on Aug 26, 2010
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
No picture or response - LG LCD TV
Hi, I have the exact same problem. I was wondering if you could tell me how you fixed it? Mine is only 2 hours old from the box
Jun 03, 2009 | LG 42LG30 42 in. LCD HDTV
I just bought my Philips 32" lcd tv and tried to hook up the ps3
you have to first plug in the s-video before you use hdmi so you can set it to HDMI on your ps3 when you go to your setting. Then it should work. If you already did that and it still doesnt work its probably the HDMI cord
Mar 30, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Cant get 42''lcd telly to let me play ps3 threw hdmi cable
You will most likely have to contact your LG dealer to fix this. The problem is due to the HDMI input not recognising the playstation, the cure for this is a software upgrade for External Device IDentification (EDID), which can only be done by a service centre.
Mar 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Surround Sound works with DVD, but not with TV, cable, etc.
dont know if it helps,but try connecting audio cables to the dvd from tv. worked for me !
Jan 05, 2009 | Sony DAVHDX265 System
Toshiba hdmi ports not working
I talked to Toshiba about his problem, this morning. They said they have never hear of such an issue. I told them the TV was less than 1 week old, and would hope Toshiba would do something in response to my alternative action of returning both my Toshiba HD DVD and 52LX177 for a new brand. They said all they can do is have me go to a service center for them to repair it. 1 week old TV and DVD, $4000, for repair; I don't think so. I talked to two different people a Toshiba regarding this, with the same answer. Very poor customer support, especially for a higher end product like this. I think I have no choice but to change brands.
Nov 18, 2007 | Televison & Video
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
54 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
