Question about Dryers
My proline tdc6a dryer isnt getting warm - Dryers
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 29, 2010
Is my dryer a fire risk
The recall covers a long period of manufacture, from April 2004 through September 2015. But there are only two types of dryers affected - Condenser and vented types.
Here are links to the Hotpoint (they make Proline) safety page that may help you to ascertain whether your model is one of the ones affected by the recall.
Safety Notice Tumble Dryers Safety Notice Tumble Dryers
Aug 01, 2016 | Dryers
Proline manuals
did u check the door switch?>
Jul 11, 2014 | Dryers
No the motor isnt running it gets alil warm and there is a slight buzzing sound
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 31, 2011 | Kenmore Dryers
My dryer isnt working. its not even getting warm
What is the make and model number of your dryer?
Jan 03, 2011 | Dryers
Proline tumble dryer TDC6A makes a loud grinding noise.
Howdy: There is a spring loaded belt tenioner that holds the belt in place. They are plastic with steel bearings. They do go out often do to the surround heat in that area. Good luck - Doug
Dec 09, 2009 | Dryers
My heater isnt working on my Proline TDC7A tumble dryer I know there are 2 thermal cutout switches which may either need resetting or renewing but where do i find them ?
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 13, 2009 | Dryers
My Maytag dryer will not stay warm
replace gas valve coils kit
Aug 16, 2009 | Dryers
Proline tdc6a taking 3 hours dry clothes
is it getting hot ? if not then its either the heating elements or thermostat. both available on espares. Most likely to be thermostats. If its heating then give the condensor a good clean. hope this helps.
Oct 29, 2008 | Dryers
Proline TDC7A Dryer (condenser)
Have you checked the connections from the pump unit to the water receiver? There are several connections at the rear of the unit which take the water from the condenser, to the pump and then to the reservoir, could be a leak? Run the machine where you can see the rear and monitor it, something may become apparent. Hope this helps. Richard
Jan 02, 2008 | Dryers
Dryers Logo
147 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
